Stock wheel, wider tires?
Old Mar 6, 2008 | 01:23 PM
Syeve's Avatar
Default Stock wheel, wider tires?
I am sure this has been covered but I can't find it anywhere. I have ab6 S4 with stock 18inch wheels. I am shopping for some summers and wouldn't mind a little bit of a wider tire. Stock is 235/40...is 245/40 possible? Any side effects? Look stupid?
Thanks guys.
Old Mar 6, 2008 | 01:24 PM
Deb38's Avatar
Default RE: Stock wheel, wider tires?
my stocks were 225's. I've seen guys run 245's
Old Mar 6, 2008 | 01:42 PM
pkid's Avatar
I had 18x8.5 rims on my 01 S4 and went with 225/40/18to keep it roughly the same. If you go wider it throws off your speedometer, and sometimes there are clearance issues...You can always call tire rack and get their opinion
Old Mar 6, 2008 | 01:45 PM
Syeve's Avatar
^^prob a safe bet. I think I will just call. Thanks!
Old Mar 6, 2008 | 02:00 PM
sweeds4's Avatar
ORIGINAL: pkid
I had 18x8.5 rims on my 01 S4 and went with 225/40/18 to keep it roughly the same. If you go wider it throws off your speedometer, and sometimes there are clearance issues...You can always call tire rack and get their opinion
with 8" i have 225's... if you have 8.5" you can def get 245's on there. whether its 225 or 245, the dolling diameter is going to be the size. only if you change to a bigger wheel, or the height of the tire is different.. ie... 225,35,18 or 225,40,18. that middle number is calculated by the ratio of the first number (225mm). so it's either 225mm x.35 or 225mm x .40. and of course we can all see that the 40 is going to yeild a larger number
mrhf99
S4
Apr 3, 2015 05:21 PM
04auditt
Nov 17, 2008 09:03 PM
DCEL
Dec 8, 2007 07:00 PM
socalaudi
Dec 12, 2005 01:07 PM
clarkkentva
Sep 12, 2004 02:02 PM
