Tail light replacement
Old Mar 23, 2008 | 06:16 PM
SHIFT_OneOffS14's Avatar
Default Tail light replacement
I need to replace the tail light bulb on the left side of the car. Does anyone have the replacement bulb part number? Is this a part I can get from a generic auto part store like Auto Zone (I freaking hope so). Lastly, how hard is it to get into the assembly and replace the bulb? Tips or pointers for DIY? Thanks.
Old Mar 23, 2008 | 09:10 PM
SilverAudiS4's Avatar
Default RE: Tail light replacement
Im pretty sure its a common bulb, just go into where ever and use the book to look up the number. Also i dont remember if you have to take the light assembly out or not but just go look at it its fairly simple shouldnt take to long and the only tool you might need would be a small maybe 10mm socket i think and thats only if you have to take the whole assembly out.
Old Mar 24, 2008 | 02:16 PM
Syeve's Avatar
^^pretty much. One bolt holds it in place. The whole process should take 5 minutes.
Old Mar 25, 2008 | 12:05 AM
Found the bulbs at the local parts store.
So the whole assembly needs to come out then?
Old Mar 25, 2008 | 01:22 AM
Since its on the drivers side i would say yes it is probably easier to take it out so you can see what your doing. Post results please
Old Mar 25, 2008 | 07:47 AM
urbnmat9's Avatar
I had the same problem where the one light was going out intermittently and I went to the local advanced auto. They have a part number for the light but the silvania bulbs had two prongs on the back instead of the one like the original. It wont fit in the slot if it has the two nubs on the back.
Old Mar 26, 2008 | 12:40 AM
ORIGINAL: urbnmat9
What did you end up doing?
I took the assembly out and changed out the bulb (it has two nubs for connectors) but it didn't fix the problem. I checked the fuse and its good to go, plus the drivers side sidemarker still works. I have no idea what the problem is. The connector at the rear seemed in good shape. All the lights work except the tail light on the drivers side. The brake light, reverse light and rear fog all work fine.Need help ASAP so this thing can pass inspection!Any suggestions?
Old Mar 26, 2008 | 12:26 PM
urbnmat9's Avatar
Sorry bud the light had just fallen out of mine and I had to go and put it back in....mine was a one prong connector and the part i got was two and the plastic would not close on teh back of the lights
Old Mar 26, 2008 | 06:31 PM
I ended up taking it into a local shop where I live to have it checked out. The car has a small oil leak going on that I wanted to get looked at as well, plus I need an inspection to get the title transfered. Figured I'd just kill a few birds with one stone...wonder how much this is going to cost me...already after only owning the car for 4 days...[:@]
ealcant718
Apr 5, 2015 04:47 AM
sabala451
May 27, 2011 01:52 AM
10scoach
Jun 12, 2008 10:08 PM
tsk
Apr 27, 2008 04:56 PM
yadude
Nov 8, 2005 12:07 AM
