for thoes with a b5 s4 and similar please read...
Old Oct 29, 2007 | 05:06 PM
SilverAudiS4's Avatar
Default for thoes with a b5 s4 and similar please read...
If you have ran a wire from the battery to the trunk either for an amp, battery relocation, or any other reason please read:
What was the route you took to get the wire from under the hood to the trunk, i was going to go down the driver side under the plastic piece by the doors but cant figure out how to get it up so anything would be grately appreciated. Thanks
Old Oct 29, 2007 | 08:16 PM
2k S4's Avatar
Default RE: for thoes with a b5 s4 and similar please read...
Best thing is to go through the rubber grommets in the fire wall, & run it through the interior to the trunk.
Old Oct 29, 2007 | 09:53 PM
audi ops's Avatar
I've heard of a little heating and melting wires problem from another S4 owner who ran speaker wires by the bottom of the door and under the backseat which just lifts up out. He smoked the inside of his car out and was so ticked he just ripped it all out .
Old Oct 29, 2007 | 09:54 PM
audi ops's Avatar
oh, I even saw where it melted the backside of the plastic..
Old Oct 30, 2007 | 11:17 AM
2k S4's Avatar
ORIGINAL: audi ops
Ok, and>? It sounds like he used to small of a gauge wire, & was running to much power. This will happen no matter where you run it.
It's your car, do what you want, as you want.
Old Oct 30, 2007 | 01:56 PM
Crank_S4's Avatar
Member
Hello!
I“ve got a amp in my trunk, but i didn“t got the + directly from the battery, but i took the power for the amp from the connections behind the fuse box inside the car. You only have to take off the lower cover underneath the steering wheel (you can see it on the pic,you can useone of the connectors inside the green circle)
[IMG]local://upfiles/42162/B1D876F6384444B7BC679FCE8A38A2B8.jpg[/IMG]
blrja6040
Jan 17, 2011 08:16 PM
VTEC_THIS
Nov 1, 2010 02:43 PM
ouTTie914
Nov 24, 2006 04:28 AM
baumer
Aug 9, 2006 11:03 PM
