What is this?
Old Dec 9, 2008 | 09:31 PM
OnlystreetraceAWD's Avatar
Default What is this?
So I was checking my vacuum lines and noticed this line is loose. It doesn't snap in tight where its supposed too. The end on the firewall is fine, its the other end that doesn't snap in tight. What does this line do? Does it need to be fastened securely? Thanks.
Old Dec 9, 2008 | 10:15 PM
Deb38's Avatar
Look as if you are pointing at the brake booster.
Old Dec 9, 2008 | 10:26 PM
drev500@aol.com's Avatar
thats you brake booster vaccum line. Its kinda important.
Old Dec 9, 2008 | 10:42 PM
LOL! well the brakes have been working fine...
so do you know why its not snapping in? or is it supposed to have something to hold it in? the end you see in the picture is not the problem... its the other end.
I'm about to go zip tie her down right now hahaha
Old Dec 11, 2008 | 09:03 PM
whats the other end thats not snaping in bc it looks like the groumet is in if thats what your talking about
Old Dec 12, 2008 | 07:19 PM
RED_01's Avatar
OnlystreetraceAWD,
What is that smaller hose connected to that is going into the booster grommet?
Is this the line you are referring to? Or are you talking about the larger hard plastic booster line?
Oh, and holy sh*t! I can't believe your coolant tank still holds liquid. Mine didn't look half that bad before it started to leak. That's crazy
Old Dec 12, 2008 | 07:35 PM
hcaudikeed's Avatar
is his coolant tank supposed to look like that?......
Old Dec 12, 2008 | 07:47 PM
RED_01's Avatar
Not supposed to but if it's old they do. Most people have to replace them because they crack and discolor.
Old Dec 13, 2008 | 04:47 PM
Deb38's Avatar
he could use a new coolant tank.
Old Dec 14, 2008 | 09:19 AM
JohnnyS4's Avatar
shokan has them for 30.00 new.
