What is the best EXHUAST.. most power?
Old Jun 8, 2008 | 06:19 PM
  #21
Deb38's Avatar
Default RE: What is the best EXHUAST.. most power?
Supposedly ASP has the best downpipes on the market.
Catback wise, you just want something that is not restrictive and fairly large.
Old Jun 13, 2008 | 01:03 AM
  #22
02audia41.8's Avatar
if i order the twin1 exhaust sytem it still needs the dp's and if so should i go with 3" asp or the apr
Old Jun 13, 2008 | 03:06 AM
  #23
Deb38's Avatar
apr is the most restrictive.
asp is the least. they cost about the same, so you might as well go ASP
Old Jun 13, 2008 | 01:34 PM
  #24
well what if i used the testpipes wouldnt it be less restrictive than the asp's
Old Jun 13, 2008 | 01:45 PM
  #25
Superdug's Avatar
SoCal Crew Member/White Devil
I say for down pipes check out these guys
http://www.jhmotorsports.com/
http://www.vastperformance.com/
either on e of them will have good deals.
Old Jun 14, 2008 | 01:10 PM
  #26
S4Doug085's Avatar
Have to say this is probably the best I've heard http://youtube.com/watch?v=LqEqXckkBKA
Old Jun 14, 2008 | 02:12 PM
  #27
say i run the asp 3" downpipes and the twin1 exhaust...will that work when i get ko4's
Old Jun 14, 2008 | 03:26 PM
  #28
S4Doug085's Avatar
Shouldn't make a difference what turbo's your using. K04's fit on the stock intake manifold so everything should work fine.
Old Jun 14, 2008 | 04:33 PM
  #29
it doesnt say on the website but does the asp downpipes come with straight pipes cause thats what i want to run
Old Jun 14, 2008 | 06:38 PM
  #30
S4Doug085's Avatar
Do cats change the sound much? I have to run cats due to inspections...not sure I want to have to swap out the exhaust every time I have to do inspections.
