What is the dif. from all these K04 turbos?
which turbo do people use on stg3 setup?
2.7T (B5 S4, C5 A6, AllRoad)
K03/K04
[*]Complete bolt on[*]Utilize stock inlet piping[*]K03 turbine wheel[*]K04 compressor wheel[*]CNC machined compressor housing[*]Quick, stock like spool[*]Increased airflow and boost capabilities over stock[*]Increased reliability[*]Updated bearing housing
Options[*]Port/Polish[*]Ceramic Coating[*]Clipped turbine Wheel[*]Zero Clearance
Price: $695 each with exchange
[hr]
[align=center]
[/align]
K03/16
[*]Complete bolt on[*]Utilize stock inlet piping[*]K03 turbine wheel (clipping is standard)[*]K16 compressor wheel[*]CNC machined compressor housing[*]Billet aluminum backplate[*]Increased flow and boost capabilities over stock K03 and K03/K04[*]Lower shaft speeds[*]Improved reliability[*]Updated bearing housing
Options[*]Port/Polish[*]Ceramic Coating[*]Zero Clearance
Price: $895.00 each with exchange
[hr]
K04-25/26
[*]OEM K04 off B5 RS4[*]K04 turbine wheel[*]K04 compressor wheel[*]Improved reliability[*]Lower shaft speeds[*]Updated bearing housing[*]Requires RS4 inlet piping
Options[*]Port/Polish[*]Wastegate Porting[*]Ceramic Coating[*]Zero Clearance[*]Clearanced Turbine Housing
Price: Email for current price
[hr]
[align=center]
[/align]
K04/RS6
[*]Based off RS4 K04 turbocharger[*]K04 turbine wheel[*]RS6 compressor wheel (larger and more efficient than RS4 K04)[*]CNC machined compressor housing[*]Billet aluminum backplate[*]Lower shaft speeds[*]Increased flow and boost capabilities over K04[*]Increased reliability[*]Updated bearing housing
Options[*]Port/Polish[*]Wastegate Porting[*]Ceramic Coating[*]Zero Clearance[*]Clearanced Turbine Housing[*]Inlet Mod[*]Upgraded Actuators
Price: $1650 each or $550/turbo to upgrade existing K04's*
*If upgrading used K04's, add $250/each for rebuild
[hr]
K04/24
[*]Based off RS4 K04 turbocharger[*]K04 turbine wheel[*]K24 compressor wheel[*]CNC machined compressor housing[*]Billet aluminum backplate[*]Lower shaft speeds[*]Increased flow and boost capabilities over K04[*]Updated bearing housing
Price: $1800 each or $750/turbo to upgrade existing K04's
K03/K04
[hr]
[align=center]
[/align]K03/16
[hr]
K04-25/26
[hr]
[align=center]
[/align]K04/RS6
[hr]
K04/24
Anything other than a ko4 seems to be a waste of money. The ko3/ko4 seems so be ok if you are on a budget but it dose not make sense to me to take a turbo that is prone to fail (ko3) and try to jazz it up
As for the other turbos I have seen severalpeople making clams but in the end I have not seen one person make any improvement in 1/4 mile time or on the dyno
But what do I know I drive a V8
Most people did Standard K04 upgrades in the past on the S4. Lately K03/k16 and k04/rs6 hybrids are coming to the front more and more as a way to make additional power. I have the k03/k16 hybrids and so far I'm very happy.
If you read the description, it's tells you what the differences are.
Most of them are Hybrid turbo's using either a K03 base (stock turbo) or a K04 base (RS4 upgraded turbo).
OTS kits are just plain jane RS4, K04's. The RS6 hybrids are a new thing for top end HP, with the much bigger turbine (cold side) wheel.
Just about all the OTS STG III software out there is for plain K04's.
When I go K04's, my thought is to get them cleaned up, & ceramic coated.
This is all from Buehn Engineerings site. As far as power levels on my setup I don't know. I went from straight k04's to the k03/k16 hybrids and noticed a big difference low end (stock like spool up) and no noticeable loss of top end. I also have GIAC/Vast stage 3 fueling and many other mods so it mightbe different for others. If I have to estimate I'd say about 450 crank hp or soon the turbos on 93 with octane booster.
thanks for the info !!...for some reason I thought they only made one type of K04 turbo...lol.
wedsite:
http://buehnengineering.com/27t.htm
wedsite:
Devil..you really think 450??
CAn someone please show me someone with hybrids that is running faster or pushing more power with hybrids over the plain k04's... AS far as i know, i havent seen it... they are more money and are riskier (in terms of not as reliable) and i havent seen the gains yet.... people say their better as their more powerful..but as far as ive seen it puts down the same amount as rs4 k04's
