What wearable components in a car would cause extreme boost lag?
Im not looking for suggestions such as boost leak, or a cracked hose.....
I want to know what can cause a car to have extreme boost lag develop over the course of 2 days after running perfectly.
Has nothing do to with the ECU, injectors, N249, intake leak.
TIA
TIA
hmm.. Im not positive on that.. i would think yes it can. But not sure.
Can you explain your symptoms a bit more.... Is it jerking at all or does it just not seem all there..or doesnt spool.. Jsut a bit more descriptive would be good.
well, for example in a low gear at around 3500rpm...
i will go WOT and the turbo will spool to 0 psi, from 20mm/hg vacuum
it will sit at 0 psi for a few hundred rpm and slowly creep up to 2 or 3 psi.
then it starts bouncing up and down between 5 and 10 psi, very irregular.
no intake leaks...brand new hyperboost DVs....brand new K04s and clutch.
problem began about 2 days after installing MBC-only. Replaced MBC with stock N75 and problem persists.
