Wheels question....please help
Old May 22, 2006 | 02:47 PM
sdkaliman's Avatar
Default Wheels question....please help
I've found some wheels that I'd like to get, but was wondering about sizing. I think I'll stick with 18's but would like to know how wide I can go while still fitting comfortably within the stock wheel wells. I want a wider stance (look) from the rear. I believe the stock Avus wheels are 18X8. Any feedback will be highly apprecited.
Old May 22, 2006 | 03:38 PM
audilover04's Avatar
Default RE: Wheels question....please help
8.5 width is popular, ive never seen 9 or wider fit under the "stock" wheel well.
Old May 22, 2006 | 10:54 PM
sdkaliman's Avatar
Thanks that helps alot.
Old May 22, 2006 | 11:45 PM
scarzie's Avatar
no, 9 can be done at stock height, and 9 can be done when dropped if u roll the fenders. A good amount of people run 9's in the rear, front is a lot tougher to fit it, but it can be done. Some people have fit 9.5 in the rear, but for that you need to have the perfect offset and tire size, which is tough to do. 8 or 8.5 are by far hte most common widths though.
Old May 23, 2006 | 03:17 PM
Hano's Avatar
i've got a question. does a rolled out fender look good, or does it kind of look weird? and how would one go about doing it yourself?
Old May 23, 2006 | 03:51 PM
sooks's Avatar
Im not positive..but i dont htink there is much visual difference... esp if done properly.. i mean your talking the matter of an inch or two...
Old May 24, 2006 | 01:53 AM
Sorry if my post was vauge. when i said 9's wouldnt fit i meant that they wouldnt fit without modifying, "rolling" the fenders or using a different offset than stock. My bad
Edit: My bad
Old May 24, 2006 | 02:12 AM
sooks's Avatar
A 9 width CAN fit without modifications with the right wheel
Old May 24, 2006 | 04:12 AM
Roadhawk's Avatar
I run 19" with 235/35s 8.5 width. Normally fine - though after I had some fairly minor body work I find I'm rubbing at the right front more often then i would like. Its mostly OK - but a bit irritating with certain road bumps/undulations and when cornering left really hard (sometimes). The damage to my wheels with the thin rubber is more of a concern - I'm constantly bending my whells - though with the RS4 replicas I'm running its a bit better then when i ran with Superleggeras...a very light but very fragile wheel....
Cocody18
Dec 19, 2012 07:28 AM
spyder
Jun 9, 2008 11:23 PM
duc_748
Apr 18, 2008 11:00 PM
i_baked_cookies
Aug 20, 2007 07:39 AM
mochamoney
Aug 9, 2006 05:38 PM
