white lights
Old Aug 22, 2006 | 02:24 AM
EuroS4's Avatar
Default white lights
hello everyone..
im kind of getting pissed off at the yellow lenses on my lights.. it makes my car look too stock...
i was looking at stores that sell the aftermarket lens, but there pretty expensive...
has anybody baked there lights and pulled the yellow out?
Subaru White Lights (BAKING)
if that worked for audis that would be amazing...
where did any of you guys get your clear lights.? cheaper stores?
thanks
Old Aug 22, 2006 | 02:33 AM
EuroS4's Avatar
Default RE: white lights
OOO **** guys i wrote a thread to Soon....
IF anybody wants clear lights... i found the website HOMEBREW>>
AUDI CLEARING LENSES
im going to do it this weekend... ill tell you how it comes out.. ill take some pics
Old Aug 22, 2006 | 04:07 AM
sooks's Avatar
no no no no no.. dont do it that way.. look at the tech section of audiworld. There is a much easier and better way to do it.
Take out the headlight from the car. take out the bulb. now drill or solder a hole in the back. i perfer solder as its much cleaner and less risk of drilling into the lens. take a screwdriver and go through that hole and break the two clips that are holding the yellow corner in.. once you break those it should slide out of place. position the piece and with 2 sets of pliers go in through the headlamp bulb hole and break the corner into pieces small enough that you can remove them. then i suggest using a mini air gun..like the kind used on computers.. to get the little pieces out.. and fill the hole and put it back.. it took me about 1 hour to do.. the first one was like 50 minutes and about 10 for the second as we figured out the process better.. tried to solder the tabs off before breaking..that didnt work. let me know if you have questions.. and the audiworld tech section hsa a better write up with pics.
Old Aug 22, 2006 | 03:39 PM
2k S4's Avatar
Break it up in the lens & pull it out threw the turn signal, much easier, the only dower is the slots left over in the lens.
Old Aug 22, 2006 | 04:18 PM
Mott Power's Avatar
.... alright, seriously, stop posting pics of your car. Too sexy!
Old Aug 22, 2006 | 05:07 PM
sooks's Avatar
ok.. i will then
right.. by the headlight hole i meant the hole from wehre teh turn signal is.
awdjunkies's Avatar
no ish!!! SEXY as hell [8D]
Old Aug 22, 2006 | 05:12 PM
Mott Power's Avatar
DAMNIT SOOKS!
nize
Jun 21, 2013 01:16 PM
A4 Effort
Apr 9, 2008 08:56 PM
tha5150
Feb 2, 2007 04:03 AM
mandeepkang
Dec 22, 2006 01:36 AM
audiA360
Jun 22, 2006 03:49 AM
