Can’t connect to my scanner
Old Nov 7, 2020 | 04:55 PM
Tavos4's Avatar
Default Can’t connect to my scanner
So I have 2013 Audi s4 and I have a schwaben scanning tool made by foxwell. I’ve used the tool in the past to see what faults I’ve had and worked just fine. I’m now trying to connect it to the car but the scanning tool itself does not even want to turn on. Any ideas of what could be causing this?? HELP also got a fault in my right beam.
Old Sep 29, 2025 | 07:45 AM
coralineweb's Avatar
It can be frustrating when your scanner won’t connect, especially when you're trying to troubleshoot an issue with your car. First, I’d recommend double-checking that the OBD-II cable is securely plugged in and that your scanner’s software is up to date. Sometimes, resetting both the scanner and the car’s system can help as well. If you're dealing with more complex diagnostics, platforms like iphone scanner apps offer great tools to complement your scanner, helping you analyze your vehicle’s data and troubleshoot problems with more precision.
Thanks for information!
Old Feb 13, 2026 | 06:35 AM
Garpangider's Avatar
If the scanner won’t even power on, it’s most likely a power/connection issue rather than a car fault. Double-check the OBD port for loose pins, bent connectors, or dirt; and make sure the key is turned to the “on” position. Sometimes the 12V supply to the port can be blown (check that fuse). If your tool still shows nothing, test it on another vehicle to rule it out. For organizing service notes or sending docs quickly, apps like https://apps.apple.com/us/app/fax-fr...pp/id978931264 can be handy. Good luck with the right beam fix!
jpjmustang
Jul 30, 2018 04:14 PM
ECS Tuning
B7 Models
Aug 14, 2017 01:03 PM
ECS Tuning
Aug 14, 2017 12:55 PM
ECS Tuning
Aug 14, 2017 12:41 PM
vjcamp
Sep 3, 2013 12:08 AM
