:: ECS Tuning :: B5 S4 Ziza LED License Plate Light Kits
Old Feb 28, 2014 | 05:22 PM
ECS Tuning's Avatar
Sponsor
Default :: ECS Tuning :: B5 S4 Ziza LED License Plate Light Kits
Ziza lighting is proud to introduce LED license plate bulbs for the B5 S4 that will not throw a bulb out code. These lights are direct replacement bulbs that install in minutes, there is no need to wire up fancy resistors or hack your factory wiring to get these to work.
Simply remove your plate light assembly, and replace the factory incandescent bulb with our Ziza bulb. When installing bulbs, be sure to place the end with the large heat sink pointing upwards, this makes sure the brightest part of the LED will be shining down on your license plate
Be Seen
Click HERE to order or for more information
Fits:
Audi B5 S4 (2000-2002)
*Note* If the bulb does not illuminate, remove the housing and reverse the bulbs position. LED bulbs have a polarity, so they must be installed correctly to illuminate.
Let me know if you have any questions.
Jason
ECS Tuning
Feb 26, 2014 01:27 PM
ECS Tuning
B8 Models
Oct 1, 2013 05:20 PM
ECS Tuning
S4
Oct 1, 2013 05:18 PM
ECS Tuning
Oct 1, 2013 05:17 PM
ECS Tuning
Apr 19, 2013 04:12 PM
