:: ECS Tuning :: B7 S4 Vent Integrated Digital Interface
Old Apr 30, 2014 | 11:47 AM
ECS Tuning's Avatar
Sponsor
Default :: ECS Tuning :: B7 S4 Vent Integrated Digital Interface
Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, the P3Cars Vent Integrated Digital Interface (VIDI) is the Swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
The P3Cars gauge is a state-of-the-art digital data center that displays critical vehicle metrics like coolant temp, intake air temp, exhaust temp, throttle plate, & RPM with shift light - as well as peak recall and run/record data, right inside your cabin.
  • Fully Reversible Installation: Simply plug into your OBD-II port and you're functional. No splicing or rewiring required.
  • Precise Color Match and OEM Integration: Seamless integration with interior lighting including auto or manual dimming to match dash brightness.
  • Advanced Custom Programming: Designed and programmed specifically for each car and engine, so you can be sure all features will function as expected.
  • Live Performance and Sensor Data: Real time “as it happens” data display of multiple parameters with virtually no lag or delay.
  • Built In Acceleration Performance Timer: Automatic start and stop 0-60mph (0-100kph) timer for evaluating your car’s performance and driving skill.
  • Diagnostic Data Interpretation & Reset: Read and clear diagnostic trouble codes (DTC) to reduce trips to the dealership.
  • 3x Analog Inputs for High Precision Sensors: Universal 0-5v inputs for adding additional sensors or switching boost to an analog vacuum tap.
  • Easiest Installation Possible: Put it in, plug it in, installation for even the most novice do-it-yourselfer.
No programming, coding, cutting, or splicing
Click HERE to order or for more information
Fits:
Audi B7 S4 2005.5-2008
Left and right hand drive models
Let me know if you have any questions.
Jason
ECS Tuning
Mar 6, 2015 03:36 PM
ECS Tuning
Mar 5, 2015 11:46 AM
ECS Tuning
Mar 5, 2015 11:22 AM
ECS Tuning
S4
Mar 5, 2015 11:00 AM
ECS Tuning
Jul 18, 2014 03:33 PM
