My reckless driving = costly repairs?
Old Sep 1, 2010 | 12:51 PM
a2thy's Avatar
Default My reckless driving = costly repairs?
Long story short, I spun out at a fairly high rate of speed and slammed my left rear wheel into a large curb causing severe gouging and slight warping of the wheel. Not only this, but it seems as though the wheel is now mounted crooked and it feels slightly loose when I pull on it. It may be unrelated, but my car now has an intermittent squeaking noise when moving, sounds kinda' like warped rotors.
Wheel replacement is a given, but my other questions are,
what kind of damage is likely?
what kind of damage is possible?
what are all the things I should thoroughly inspect, and what exactly should I be looking for?
Old Sep 1, 2010 | 12:58 PM
hiwords's Avatar
have you taken that wheel of to take a look. i'd say wheel bearing and CAs
Old Sep 1, 2010 | 01:53 PM
ImTheDevil's Avatar
I'd bet minimum you need spindle, CAs, wheel, strut, and possibly spring. Drive axle wouldn't surprise me either and make sure you check the diff mount, in case it was damaged.
Old Sep 1, 2010 | 01:58 PM
Andrew149's Avatar
Mostly lower control arm is bent to **** tie rod would be bent and upper control are thats about it
Old Sep 1, 2010 | 07:05 PM
twoeightquattro's Avatar
how'd you end up spinning out with quattro.
rain?
Old Sep 2, 2010 | 01:57 AM
Msnickbroderick's Avatar
Actual WIZARD
I spun my FWD at 40 and walked away needing an aligment (and putting 2 kinks in the drivers side wheels, loosing the plastic skid plate, scuffing the oil pan, and actually denting the underbody, all of which is still working to this day) My steering wheel looked like this when driving straight:
So just do what I did, spend a day looking over your car (take the wheels off, look at bolts, nuts, anything really) and see what you come up with. Might even help to get a tape measure and check driver/pass sides for spacing consistency
Old Sep 2, 2010 | 08:14 AM
chocalotstarfish's Avatar
Super Moderator
I did that is my transam needed a new control arm. I tore that **** up bad! I bent the whole side to a 45 degree angle!
Old Sep 2, 2010 | 01:57 PM
russcuss36's Avatar
ImtheDevil is 100% right. You probably really messed up everything. I would try to get that stuff from a Junk Yard if Possible. Why did you mess up a nice car? Your suppose to do that when you are young and dumb. Take care of your Audi and it will take care of you.
Old Sep 2, 2010 | 02:45 PM
Andrew149's Avatar
What no these cars are dead solid when it comes to wrecking its mostly a bent arm i have been in a bad acident hitting 2 curbs at 60 and the car still drives straight i bent the arms so bad the wheel pointed the opposite direction
Old Sep 7, 2010 | 06:25 PM
a2thy's Avatar
I did a lot of reckless things due to the prescription drugs I was on at the time. I'm off them now, but I have too many other things I need to take care of right now, so my car will have to wait until I get the time and ambition to work on it. I just bought another vehicle so I can still get around until I fix my Audi.
bigbod35
Sep 7, 2010 12:02 PM
a2thy
Sep 1, 2010 12:56 PM
quattro225TT
Feb 17, 2008 04:42 PM
lando0077
Dec 4, 2007 05:00 PM
