Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
allroad suspension
Old Oct 24, 2022 | 01:01 PM
amazon1's Avatar
Default allroad suspension
Hi all
i replaced nearside front airbag, replaced both front residuel valves, was working ok but orange light started to flash, now jack mode is greyed out in on position so cannot alter height, orange light permanently on now, ...anyone help out, also tried to re-calibrate suspension but will not go past 1st of height measure....
Old Jan 28, 2024 | 01:29 AM
davideidson's Avatar
Thumbs up
Check for any additional error codes related to the suspension system using a diagnostic scanner to pinpoint the issue causing the flashing orange light.
Verify that all connections and sensors related to the airbag replacement and suspension system are properly secured and functioning. If issues persist, consult a professional mechanic or dealership for a thorough inspection and resolution.
Carpetsteve24
Aug 18, 2016 06:23 AM
Ventilator
Nov 4, 2013 11:07 AM
HeyJud7
Sep 27, 2011 01:49 PM
myaudi98
Jun 10, 2008 12:51 PM
H2JMC
Jun 18, 2005 01:45 AM
