Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
B6 A4 Shock Replacement - Spinning Shock
Old Jun 15, 2012 | 10:46 PM
mightyb28's Avatar
Exclamation B6 A4 Shock Replacement - Spinning Shock
Here is the deal. I just pulled one of my front shocks, as i am replacing with a stasis kit, and when i try to get the nut off the top shock mount.
I am using an impact gun and all that happens is the shock rod , the nut is attached to, just spins. I tried a crescent wrench, a pipe wrench and nothing. Wasted all that time and had to put it back together.
Can anybody tell me how to get this nut off??????
Old Jun 16, 2012 | 07:57 AM
derZeck's Avatar
sometimes you need to use a pair of vise grips to hold the shaft
Old Jun 16, 2012 | 10:17 AM
mightyb28's Avatar
Tried vice grips too. Maybe they were not big enough, but the shock shaft is so smooth that it still spins.
Old Jun 19, 2012 | 01:31 PM
pa4ul's Avatar
:: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
I used needle nose for mine and had my buddy hold one while i spun the other.
Old Jun 20, 2012 | 11:34 PM
mightyb28's Avatar
Needle nose pliers? So what did you have him hold on to?
Old Jun 21, 2012 | 12:12 PM
pa4ul's Avatar
I used a wrench while he held the pliers. had the bottom of the shock in a too a bit of tugging but it broke free. had the bottom of the shock in a vise to hold steady and twisted from bottom while unscrewing from top. if that makes any sense to you.
Old Jun 22, 2012 | 01:38 PM
mightyb28's Avatar
Hopefully I will have time to yank the shock out this weekend, but I didn't see the top piece you have pointed out. Thank you and i will take a look. also the bottom of the shock does not keep the internal from spinning on mine. If I don't find it I have heavy duty vice grips.
I am not sure why audi designed the suspension this way, but thank god replacing shocks is a one time thing.
Old Jul 3, 2012 | 05:30 PM
pa4ul's Avatar
yea the rear shocks are probably the most straightforward swap in our cars.
Julio Quevedo
May 21, 2012 08:24 AM
escyr
Apr 25, 2009 09:33 AM
