Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
how much is installation
Old 02-21-2007, 12:24 AM
dblock110's Avatar
Default how much is installation
im about to buy these lowering springs from eibach for only 260. they lower my 98 a6 1.75 in front, 1.5 in back. i was told this is all i need. how much is installation for this work?
Old 02-23-2007, 01:30 PM
panzrwagn's Avatar
Default RE: how much is installation
Yes you CAN replace just the springs. For a 2-3 hours labor ($200-$300 in a shop) and a 4-wheel alignment ($100). You have a 9-year old car.You SHOULD replace the rubber spring mounts (to avoid squeaking suspension syndrome) and the parts are cheap - about $20 each..
You SHOULD also consider replacing the shocks with either Koni or Bilstein Sport shocks thatare shorter to accomodate the lowered springs. Otherwise, the stock shocks are 1) offset in their travel using up most of their compression travel; 2) offset in their damping setup and can't possibly handle optimally, and 3) your stock shocks are probably about gone anyway. If not they will be in a couple months of trying to damp a stiffer lowering spring and bottoming out on bumps.
A lot of folks who complain about bad ride with lowering springs are experiencing this. Shocks and springs are a tuned system, and just replacingjust shocks or springsupsets the tuning unless they are designed to work together.
Consider a matched kit from Eibach, H&R, KW or Vogtland. You'll be much happier and in the end will have spent less time and money on labor and phone calls complaining.
Old 02-25-2007, 02:38 PM
VW01AUDI00's Avatar
Yeah definitly buy new struts/shocks your going to have a bumpy ride if you just put the springs on your old struts they're probaly shot after about 60,000 anyways.Its going to cost you $150-$300 just to put the springs on and another $100 for alingnment.You don't want to pay for that twice your car will be setup the right way and ride great .You'll get a better deal if you buy every thing together try www.awetuning.com or www.purems.com to see some of the packages.
Audion
07-08-2011 04:10 PM
Bosno
04-04-2009 02:17 PM
Leifer
07-22-2008 09:11 PM
Keyboard Ninja
05-26-2007 05:11 PM
kovalchuk71
02-21-2007 07:18 PM
Quick Reply: how much is installation
