Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
i need help with lowering kit...
Old 02-20-2007, 10:35 PM
audia4's Avatar
Default i need help with lowering kit...
I am in the process of buying an 02 or 03Audi A4 1.8T and want to do all of the modifications the day that I get it. I am going to get 17 or 18" rims, and want to lower the car. I want to know what is the best way to do this, and how much is the lowering kit going to cost. I would be installing this kit myself. Please let me know. What would I need besides lowering springs, etc???
Old 02-20-2007, 11:08 PM
leighsean's Avatar
Default RE: i need help with lowering kit...
$250 to $350 for springs only or $1000 or more for a strut & spring set up. you might hane to order your wheels because alot of shops dont stock the bolt patterns that audis use. the lowering kits are pretty easy to install given you have the appropriate tools. good luck and welcome to audiforums.
Old 02-20-2007, 11:37 PM
audia4's Avatar
I'm new to cars, I am usually working on lifted trucks, and am very unfamiliar with cars suspensions. Do you only need the lowering springs, or are complete kits necessary???
Old 02-20-2007, 11:44 PM
leighsean's Avatar
either one will do. if you want a stiffer "race" style suspension then get a spring/strut combo, if money is an issue or if you dont mind a softer supension then just buy springs. keep in mind that either kit will be stiffer than the stock susp.
Old 02-21-2007, 12:44 AM
audia4's Avatar
i am planning on running either 17, 18 or 19" rims. any idea on what drop springs that i should run with these? thanks a lot
Old 02-21-2007, 01:27 PM
leighsean's Avatar
im runnin 19's with about a 3.5 in drop
lower it first then buy rims so they can test fit.
Old 02-21-2007, 02:25 PM
MissionCtrl's Avatar
17,18, or 19's aren't going to make a difference. its all about how wide they are, thats where you run into problems when you lower the car.
Old 02-22-2007, 02:06 PM
leighsean's Avatar
thats why i say lower it first
Old 02-22-2007, 08:17 PM
audia4's Avatar
would i need new shocks in addition to these springs?....?
Old 02-22-2007, 09:28 PM
ThePapaCMan's Avatar
Yeah you would. Your old shocks will bust in a few months, especially with a big drop. You can either get springs + shocks, that sit at a certain height, or for alittle more you can get coilovers where you can adjust the height to anything you want.
Quick Reply: i need help with lowering kit...
