Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
need some help with suspension setup
Old Nov 4, 2019 | 08:24 AM
knotcher's Avatar
Default need some help with suspension setup
2008 A3 with 181k miles
stock suspension
audi tt wheels (1/2" wider than stock)
10mm spacers so the wheels clear the brakes
when i'm in the car by myself, no problem. if the car is weighed down at all, like if my 10yr old gets in, and i hit a bump the tires scrape the fender wells. i guess i could just cut the lining out of the fender wells, but i'd really like to solve this problem without doing that if possible.
so...
most suspension upgrades out there involve lowering the car. i'm afraid that even with a stiffer suspension the lowering will cause the same rubbing effect.
are there options that i don't know about that will stiffen the suspension but not lower?
any other thoughts?
Old Nov 4, 2019 | 08:54 AM
Redneck Slim's Avatar
Take a look at the springs for the factory Sport Suspension (like my 2013 A3 has). These should be stiffer without lowering the car.
Old Nov 4, 2019 | 10:01 AM
I also added a stiffer H&R rear bar (from ECS Tuning). This reduces body roll and helps with wider wheels and tires.
alexrussell1988
Feb 22, 2008 01:31 PM
i_baked_cookies
Apr 25, 2007 02:52 AM
haulin79
May 10, 2006 09:05 PM
kakarot
Mar 16, 2006 11:54 PM
