VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
A4 B5 - ABS error - VAGcom error
Old Mar 30, 2010 | 11:42 AM
vtraudt's Avatar
Default A4 B5 - ABS error - VAGcom error
The instrument cluster is lit up like a Christmas tree. Trying to find out where to start trouble shooting, I plugged the VAGcom in, but get this error. Does a bad ABS module generate the error? I only found hints that a bad ABS module create error messages, but not that is does not connect at all?
Old Mar 30, 2010 | 09:14 PM
vtraudt's Avatar
I have another ABS module. Before attempting the change: can I access the ABS module from the top of the engine bay? What has to be removed? Disconnect battery (and create all the associated 'log out' problems?
The module that I have is here (it is supposedly for a 1998 A4 B5). Will it fit?:
DCAV8R
Jan 23, 2023 06:33 AM
Badman
Oct 3, 2009 12:28 PM
ilovelagar
Oct 22, 2008 12:37 PM
2ez123
Jun 8, 2008 12:45 PM
BONFIRE074
Aug 4, 2007 02:08 AM
