Audi A4 2005 wont start
Hi Im new to the forum been having a terrible time figuring out were to start
Recent work done is replaced thermostat, remove throttle body and repalce the battery put it all back together and it wont start here are the fault codes that came up when i used vag-com Thursday,09,July,2015,17:11:55:33938 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.10.2.0 (x64) Data version: 20150311 Ross-Tech: Home VIN: WAULC68E75A119136 Mileage: 168640km-104788mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAULC68E75A119136 Mileage: 168640km-104788miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06B-909-518-AMB.lbl Part No SW: 8E0 909 518 BC HW: 8E0 909 018 A Component: 1.8L R4/5VT G 0020 Revision: 00000000 Serial number: AUZ6Z0D0371843 Coding: 0016751 Shop #: WSC 06335 000 00000 VCID: 72E5C9E46E2BB3B168B-515A 1 Fault Found: 17072 - ECM Power Relay Load Circuit P0688 - 004 - Open Circuit Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01V-927-156.lbl Part No: 8E0 927 156 AA Component: AG5 01V 1.8l5VT USA 0505 Coding: 0001002 Shop #: WSC 06335 000 00000 VCID: 6DDFDA9877156C49B59-515A 1 Fault Found: 18258 - Powertrain Data Bus P1850 - 003 - Missing Message from ECU - Intermittent - MIL ON ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 A Component: ABS/ESP allrad 4529 Coding: 04277 Shop #: WSC 06435 VCID: 264DE5B4C2639F11343-513C 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-00 - - ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AC Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06335 VCID: 62C5B9A4EECB233118B-515A 1 Fault Found: 01206 - Signal for Duration of Ignition Off Time 27-00 - Implausible Signal ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul USA 0517 Coding: 00003 Shop #: WSC 06335 VCID: 356F32F80FC5E4898D9-4B32 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 K Component: Airbag 8.4EP 1001 Coding: 0010607 Shop #: WSC 06335 000 00000 VCID: 3F8350D06DF92ED9575-515A No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 N Component: Lenksáulenmodul 0611 Coding: 01041 Shop #: WSC 06335 VCID: 3E7D2DD43AF327D15C3-4B32 2 Faults Found: 00474 - Control Module for Immobilizer 49-10 - No Communications - Intermittent 01044 - Control Module Incorrectly Coded 35-00 - - ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 950 P Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 01231 Shop #: WSC 00001 VCID: 366D35F412C3EF91843-5178 WAULC68E75A119136 AUZ6Z0D0371843 3 Faults Found: 01176 - Key 07-10 - Signal too Low - Intermittent 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent 01314 - Engine Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BB Component: Komfortgerát T7B 1612 Coding: 11788 Shop #: WSC 06335 VCID: 72E5C9E43E2BB3B168B-4B32 Subsystem 1 - Part No: 8E1959801 Component: Tőrsteuer.FS BRM 0205 Subsystem 2 - Part No: 8E1959802E Component: Tőrsteuer.BF BRM 0205 Subsystem 3 - Part No: 8E0959801A Component: Tőrsteuer.HL BRM 0205 Subsystem 4 - Part No: 8E0959802A Component: Tőrsteuer.HR BRM 0205 4 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 00955 - Key 1 35-10 - - - Intermittent 00956 - Key 2 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 195 H Component: symphony II PM6 0410 Coding: 00001 Shop #: WSC 26112 VCID: 2C59179CDC8FA541E27-50AC 5 Faults Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent 00878 - Connection to Speaker Front Left 36-10 - Open Circuit - Intermittent 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 29-10 - Short to Ground - Intermittent 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 36-00 - Open Circuit 01305 - Databus for Infotainment 49-10 - No Communications - Intermittent End-------------------------(Elapsed Time: 04:56)-------------------------- |
Where to start, at the beginning.
make sure the battery is fully charged.
make sure it is connected, securely. make sure all the connections, and plugs in the engine bay etc are reconnected and secure. clear the codes. and see what comes back on the attempt to start. externally to checking for codes. See if you have fuel pump running, and a spark. good luck. |
