VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Audi A4 2005 wont start
Old Jul 9, 2015 | 11:09 PM
Tomamador's Avatar
Unhappy Audi A4 2005 wont start
Hi Im new to the forum been having a terrible time figuring out were to start
Recent work done is replaced thermostat, remove throttle body and repalce the battery put it all back together and it wont start here are the fault codes that came up when i used vag-com
Thursday,09,July,2015,17:11:55:33938
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
Ross-Tech: Home
VIN: WAULC68E75A119136
Mileage: 168640km-104788mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAULC68E75A119136 Mileage: 168640km-104788miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 BC HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0020
Revision: 00000000 Serial number: AUZ6Z0D0371843
Coding: 0016751
Shop #: WSC 06335 000 00000
VCID: 72E5C9E46E2BB3B168B-515A
1 Fault Found:
17072 - ECM Power Relay Load Circuit
P0688 - 004 - Open Circuit
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 AA
Component: AG5 01V 1.8l5VT USA 0505
Coding: 0001002
VCID: 6DDFDA9877156C49B59-515A
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 003 - Missing Message from ECU - Intermittent - MIL ON
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 4529
Coding: 04277
Shop #: WSC 06435
VCID: 264DE5B4C2639F11343-513C
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AC
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 06335
VCID: 62C5B9A4EECB233118B-515A
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 00003
Shop #: WSC 06335
VCID: 356F32F80FC5E4898D9-4B32
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
VCID: 3F8350D06DF92ED9575-515A
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 06335
VCID: 3E7D2DD43AF327D15C3-4B32
2 Faults Found:
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 00001
VCID: 366D35F412C3EF91843-5178
WAULC68E75A119136 AUZ6Z0D0371843
3 Faults Found:
01176 - Key
07-10 - Signal too Low - Intermittent
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
01314 - Engine Control Module
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1612
Coding: 11788
Shop #: WSC 06335
VCID: 72E5C9E43E2BB3B168B-4B32
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0205
4 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0410
Coding: 00001
Shop #: WSC 26112
VCID: 2C59179CDC8FA541E27-50AC
5 Faults Found:
00532 - Supply Voltage B+
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
29-10 - Short to Ground - Intermittent
36-00 - Open Circuit
01305 - Databus for Infotainment
End-------------------------(Elapsed Time: 04:56)--------------------------
Old Oct 8, 2015 | 02:24 AM
bydand's Avatar
Default Where to start, at the beginning.
make sure the battery is fully charged.
make sure it is connected, securely.
make sure all the connections, and plugs in the engine bay etc are reconnected and secure.
clear the codes.
and see what comes back on the attempt to start.
externally to checking for codes. See if you have fuel pump running, and a spark.
good luck.
Robi959
B7 Models
Jan 11, 2020 07:28 PM
victoria_73
Oct 18, 2014 11:23 PM
mark944turbo
Oct 10, 2005 05:51 PM
