P2279, p2187, p0300
having same issue
Replaced PCV valve
Replaced all 4 Coils
Replaced all 4 Spark Plugs
Changed air filter and cleaned Mass Air Flow sensor
Changed oil and filter
I had more codes to start with but am currently left with those same codes and also a P12A2 which might point towards a faulty fuel sensor.
Anything you remember on your ultimate fix would be useful in my trying to figure this out without getting financially pillaged at a dealership.
Thanks a million!
Mike
Punch your codes into google to get a definition for them - ex "Audi p0300" (which is a random misfire). That's a start toward figuring it out. Reply with your results on the other two and any relevant info on your car (i.e., recent work done to it, etc) and we can try and go from there.
Did you ever get a solution for this figured out? I am dealing with the exact same issue. I have tried the following,
Replaced PCV valve
Thanks a million!
Mike
Replaced PCV valve
Thanks a million!
Mike
Sorry for delayed response, car had a vacuum leak from bad PCV valve causing real main seal to blow a bit. Repairs were too expensive so I ate the loss and dumped the car. Done with Audi forever. PoS vehicle.
Renifer
B7 Models
11-21-2013 09:08 PM
