Cecm recode
So I ran vag com on my car and it came up that the cecm module was out. I purchased a replacement. I plug it all in and now my running lights stay on and cant turn off unless I turn the car off. also my fog lights turn on until I turn on my headlights to auto or on. then the headlights come on and fogs turn off. I been searching to find out if I may have to recode the cecm. Can anybody help . here is the latest vag com from my car.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul KAN 0517 Coding: 01014 Shop #: WSC 06435 VCID: 356F2B740F49B1B6775-4B18 9 Faults Found: 00985 - Right Tail Light (M2) 57-00 - Electric Circuit Failure 01500 - Bulb for Fog-Lamps; Right (L23) 57-00 - Electric Circuit Failure 01794 - Control Module - Incorrect Chassis (VIN) Number 35-00 - - 01330 - Central Control Module for Central Convenience (J393) 49-10 - No Communications - Intermittent 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent 01332 - Door Control Module; Passenger Side (J387) 49-10 - No Communications - Intermittent 01333 - Door Control Module; Rear Left (J388) 49-10 - No Communications - Intermittent 01334 - Door Control Module; Rear Right (J389) 49-10 - No Communications - Intermittent 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent |
Hi, I'm an ex Audi tech. You can't just replace the central electrics ecu, you have to run the test plan via the diagnostic tester (vas pc) to replace it. This procedure extracts the stored data from your existing component and inputs it into the new one. To try overcome it now, you will need to get the coding of the ecu (via your printout) and manually change the code of the new one with a compatible tester. This is why you are experiencing a difference in functionality of the lights.
I think I read somewhere that in an old vag com scan it should contain the coding that I need to input into the new one. This has been such a headache you've been more help then anyone. The local Audi isn't to friendly here.
