Help with codes
I was deployed overseas for 6 months and came back and seems to be one problem after the next. I've replaced my ABS wheel speed senor, but I keep getting fault codes that I was hopping was just the right rear sensor. On top of that my check engine light came on. I live in ND and nearest Audi dealership is 4hours. any recommendations would be greatly appreciated. 2011 Audi Q7 Prestige:
Address 01: Engine (CJW) Labels: None Part No SW: 4L0 910 551 H HW: 4L0 907 551 A Component: 3.0l V6 TFSI 0020 Revision: --H07--- Serial number: Coding: 0121000A290F0928 Shop #: WSC 31414 790 00001 VCID: 2D5B38FDB4BF8B2972-8078 4 Faults Found: 053271 - Please Check Fault Codes in Control Module for ABS Brakes U1017 - 000 - Freeze Frame: Fault Status: 01101000 Fault Priority: 1 Fault Frequency: 109 Reset counter: 255 Mileage: 145651 km Time Indication: 0 Date: 2017.02.15 Time: 16:24:03 Freeze Frame: RPM: 1312 /min Mass Air / Rev.: 207.1 mg/str Temperature: 27.0°C Bin. Bits: 00000010 Load: 23.9 % Speed: 0.0 km/h 006535 - Function Limited due to Brake Temperature P1987 - 000 - Freeze Frame: Fault Status: 01101000 Fault Priority: 1 Fault Frequency: 109 Reset counter: 255 Mileage: 145651 km Time Indication: 0 Date: 2017.02.15 Time: 16:24:03 000771 - Cylinder 3 P0303 - 000 - Misfire Detected - MIL ON Freeze Frame: Fault Status: 11100010 Fault Priority: 6 Fault Frequency: 1 Reset counter: 255 Mileage: 152146 km Time Indication: 0 Date: 2017.05.27 Time: 01:14:57 Freeze Frame: RPM: 1248 /min Mass Air / Rev.: 294.3 mg/str Temperature: 27.0°C Bin. Bits: 00000010 Time: 0.0 s Speed: 0.0 km/h 004874 - Cylinder Disabling P130A - 000 - - Intermittent Freeze Frame: Fault Status: 11100010 Fault Priority: 6 Fault Frequency: 1 Reset counter: 255 Mileage: 152146 km Time Indication: 0 Date: 2017.05.27 Time: 01:14:57 Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q Component: AL1000 AISIN 001 1863 Serial number: Coding: 001378 Shop #: WSC 27714 002 1048576 ASAM Dataset: EV_TCMAL991031 001001 ROD: EV_TCMAL991031_001.rod VCID: 3A7103A1BDF12C91E7-806E 1 Fault Found: 12837 - Implausible Data Received from ABS Control Module U0415 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 8 Reset counter: 201 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.0 /min Transmission input speed: 0 /min Transmission output speed: 0 /min Engine torque: -36 Nm Transmission fluid temperature: 34 °C Accelerator position: 0.0 % Clutch status: Open Clutch status: Open Clutch status: Open Clutch status: Open Clutch status: Open Clutch status: Open Clutch status: Open EOP target revolution: 65534 /min EOP actual revolution: 65279 /min Engine Speed signal Current: 65279 /min EOP failure status with EOP without HV: Motor normal stop EOP target current: 65278 mA ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb Part No SW: 4L0 910 517 M HW: 4L0 614 517 L Component: ESP ALLRAD MK25E1 0020 Revision: 00H02001 Coding: 0103505 Shop #: WSC 31414 790 00001 VCID: 346D2D995795DAE13D-8060 2 Faults Found: 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 33 Mileage: 152157 km Time Indication: 0 Date: 2017.05.27 Time: 17:23:16 Freeze Frame: Count: 128 Count: 8513 Count: 86 Count: 42496 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 33 Mileage: 152157 km Time Indication: 0 Date: 2017.05.27 Time: 17:23:16 |
