VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Help with codes
Old May 31, 2017 | 08:46 AM
vondutchoby87's Avatar
Default Help with codes
I was deployed overseas for 6 months and came back and seems to be one problem after the next. I've replaced my ABS wheel speed senor, but I keep getting fault codes that I was hopping was just the right rear sensor. On top of that my check engine light came on. I live in ND and nearest Audi dealership is 4hours. any recommendations would be greatly appreciated. 2011 Audi Q7 Prestige:
Address 01: Engine (CJW) Labels: None
Part No SW: 4L0 910 551 H HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0020
Revision: --H07--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 31414 790 00001
VCID: 2D5B38FDB4BF8B2972-8078
4 Faults Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 109
Reset counter: 255
Mileage: 145651 km
Time Indication: 0
Date: 2017.02.15
Time: 16:24:03
Freeze Frame:
RPM: 1312 /min
Mass Air / Rev.: 207.1 mg/str
Temperature: 27.0°C
Bin. Bits: 00000010
Load: 23.9 %
Speed: 0.0 km/h
006535 - Function Limited due to Brake Temperature
P1987 - 000 -
Freeze Frame:
Fault Priority: 1
Reset counter: 255
Mileage: 145651 km
Time Indication: 0
Date: 2017.02.15
Time: 16:24:03
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 152146 km
Time Indication: 0
Date: 2017.05.27
Time: 01:14:57
Freeze Frame:
RPM: 1248 /min
Mass Air / Rev.: 294.3 mg/str
Temperature: 27.0°C
Bin. Bits: 00000010
Time: 0.0 s
Speed: 0.0 km/h
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 152146 km
Time Indication: 0
Date: 2017.05.27
Time: 01:14:57
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 001 1863
Serial number:
Coding: 001378
Shop #: WSC 27714 002 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001.rod
VCID: 3A7103A1BDF12C91E7-806E
1 Fault Found:
12837 - Implausible Data Received from ABS Control Module
U0415 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 8
Reset counter: 201
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: -36 Nm
Transmission fluid temperature: 34 °C
Accelerator position: 0.0 %
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
EOP target revolution: 65534 /min
EOP actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
EOP failure status with EOP without HV: Motor normal stop
EOP target current: 65278 mA
Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0103505
VCID: 346D2D995795DAE13D-8060
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
008 - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 152157 km
Time Indication: 0
Date: 2017.05.27
Time: 17:23:16
Freeze Frame:
Count: 128
Count: 8513
Count: 86
Count: 42496
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 152157 km
Time Indication: 0
Date: 2017.05.27
Time: 17:23:16
Sammy~D
Mar 7, 2013 08:59 PM
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
TurboToughTT
May 14, 2008 02:19 PM
03a4uc
Nov 24, 2007 08:44 PM
