HELP WITH VAGCOM PLEASE
Ok, I purchased a OBD11 interface usb cable. downloaded vagcom 409.1 from the vagcom site. I loaded the usb driver as instructed on the vagcom site. When i open vagcom and tick the usb button and then test. It returns the following, port OK , no interface found. Can anyone help please
on com3 i get the following port OK, Interface found, Type, serial pass through, ross Tech No.
So it looks like its working. When i plug it into the car it seems to keep trying to access controllers but cant, i have the ingnition on. I have an audi, A4 2002 1.8T
I plugged into the car and if i do a compatabilty test it says my car is not OBD11 Compliant . Please can someone give me any ideas, I undedrstood the car should be , Its a 2002 1.8T avent
not 100% if 409.1 is CAN related it has to be HEX type and never did like the USB cable type as it could be you dont have the software/driver to run it that's why serial is best because its set to coms port 1 as standard and less problems
edit: worth a read
http://www.ross-tech.com/vag-com/vag-com-faq.html
edit: worth a read
