My new Vag & first auto scan (buttloads of codes)
Okay so my new vag came and I ran my first auto scan and what the hell!!!:eek::eek::eek:
Sunday,29,September,2013,02:20:30:22822 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: WAUJC68E24A012338 License Plate: NEW01 Mileage: 134970km-83866mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUJC68E24A012338 Mileage: 134970km/83866miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06B-909-518-AMB.lbl Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A Component: 1.8L R4/5VT G 0003 Coding: 0016501 Shop #: WSC 06435 000 00000 VCID: 79F91DAA338074D6D3D-5140 4 Faults Found: 18107 - Powertrain Data Bus P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent 18058 - Powertrain Data Bus P1650 - 004 - Missing Message from Instrument Cluster - Intermittent 18043 - Powertrain Data Bus P1635 - 008 - Missing Message from A/C Controller - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 008 - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 3429 Coding: 04275 Shop #: WSC 06435 VCID: E5C1C1DA7F386036875-5140 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AC Component: A4 Klimaautomat 1450 Coding: 00000 Shop #: WSC 22309 VCID: 62CB5AC6EE16970EE27-5140 4 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 00474 - Control Module for Immobilizer 49-10 - No Communications - Intermittent 01794 - Control Module - Incorrect Chassis (VIN) Number 35-00 - - 00474 - Control Module for Immobilizer 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00011 Shop #: WSC 00000 VCID: 3561D19A0F1850B6775-4B00 4 Faults Found: 01794 - Control Module - Incorrect Chassis (VIN) Number 35-00 - - 01800 - Light Switch (E1) 27-10 - Implausible Signal - Intermittent 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 01317 - Control Module in Instrument Cluster (J285) 79-10 - Please Check Fault Codes - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 C Component: Airbag 8.4EP 2000 Coding: 0010607 Shop #: WSC 06435 000 00000 VCID: 377DDB924514A2A6659-5140 2 Faults Found: 01794 - Control Module - Incorrect Chassis (VIN) Number 000 - - - Intermittent 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 N Component: Lenksáulenmodul 0308 Coding: 00041 Shop #: WSC 06435 VCID: 3E73CEB63A2E93EEA6F-4B00 3 Faults Found: 00474 - Control Module for Immobilizer 49-10 - No Communications - Intermittent 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 01794 - Control Module - Incorrect Chassis (VIN) Number 35-00 - - ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 950 L Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 02200 Shop #: WSC 00000 VCID: 326BEA86FE76478E527-5140 Subsystem 1 - Part No: WAUJC68E24A Component: PÏPÏP AUZ6Z0C0125982 WAUJC68E24AÏPÏPÏP AUZ6Z0C0125982 2 Faults Found: 01304 - Radio 49-10 - No Communications - Intermittent 01311 - Information Data Bus 37-10 - Faulty - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BB Component: Komfortgerát T7B 1311 Coding: 11788 Shop #: WSC 06435 VCID: 72EB2A863EF6078E927-4B1A Subsystem 1 - Part No: 8E1959801 Component: Tõrsteuer.FS BRM 0003 Subsystem 2 - Part No: 8E1959802E Component: Tõrsteuer.BF BRM 0003 Subsystem 3 - Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0003 Subsystem 4 - Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0003 7 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 00962 - Alarm via. Tilt Sensor 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch; Passenger Side 35-00 - - ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00060 Shop #: WSC 06435 VCID: 04077C5E1442393EB0B-4B32 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 195 H Component: symphony II NP2 0260 Coding: 01201 Shop #: WSC 22016 VCID: 2C57F4FEDC52117E18B-5074 3 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 36-00 - Open Circuit 01305 - Databus for Infotainment 49-10 - No Communications - Intermittent End --------------------------------------------------------------------- |
I just cleared eveything and I'm going to re scan in a day or 2
Well, looks like you have a mess. Might have to take it to a dealer.
? the mileage. Ken G |
Originally Posted by kengrant
(Post 1450371)
hello I got a 2001 a6 and my battery went dead now the radio went into the SAFE mood and I cant retrieve the code because the radio card wasn't in the car when I purchase it .. how can I retrieve that radio code
Not sure, there might be a better section to ask that question here on AF, good luck!!
