VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
My new Vag & first auto scan (buttloads of codes)
Old Sep 29, 2013 | 12:57 PM
californiadaddy's Avatar
Default My new Vag & first auto scan (buttloads of codes)
Okay so my new vag came and I ran my first auto scan and what the hell!!!
Sunday,29,September,2013,02:20:30:22822
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUJC68E24A012338 License Plate: NEW01
Mileage: 134970km-83866mi Repair Order:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUJC68E24A012338 Mileage: 134970km/83866miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0003
Coding: 0016501
Shop #: WSC 06435 000 00000
VCID: 79F91DAA338074D6D3D-5140
4 Faults Found:
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
18058 - Powertrain Data Bus
P1650 - 004 - Missing Message from Instrument Cluster - Intermittent
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04275
Shop #: WSC 06435
VCID: E5C1C1DA7F386036875-5140
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AC
Component: A4 Klimaautomat 1450
Coding: 00000
Shop #: WSC 22309
VCID: 62CB5AC6EE16970EE27-5140
4 Faults Found:
00474 - Control Module for Immobilizer
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
27-10 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 00000
VCID: 3561D19A0F1850B6775-4B00
4 Faults Found:
35-00 - -
01800 - Light Switch (E1)
79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
VCID: 377DDB924514A2A6659-5140
2 Faults Found:
000 - - - Intermittent
004 - No Signal/Communication - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 06435
VCID: 3E73CEB63A2E93EEA6F-4B00
3 Faults Found:
35-00 - -
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 02200
Shop #: WSC 00000
VCID: 326BEA86FE76478E527-5140
Subsystem 1 - Part No: WAUJC68E24A
Component: PÏPÏP AUZ6Z0C0125982
WAUJC68E24AÏPÏPÏP AUZ6Z0C0125982
2 Faults Found:
01304 - Radio
01311 - Information Data Bus
37-10 - Faulty - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 06435
VCID: 72EB2A863EF6078E927-4B1A
Subsystem 1 - Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0003
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0003
7 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 06435
VCID: 04077C5E1442393EB0B-4B32
No fault code found.
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0260
Coding: 01201
Shop #: WSC 22016
VCID: 2C57F4FEDC52117E18B-5074
3 Faults Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
36-00 - Open Circuit
01305 - Databus for Infotainment
End ---------------------------------------------------------------------
Old Sep 29, 2013 | 04:33 PM
I just cleared eveything and I'm going to re scan in a day or 2
Old Oct 7, 2013 | 09:46 PM
kengrant's Avatar
Well, looks like you have a mess. Might have to take it to a dealer.
? the mileage.
Ken G
Old Oct 8, 2013 | 04:33 PM
? the mileage.
Ken G
I cleared all the codes, and the re-coded all the modals, and Im good to go now. I know the mileage is correct, I ran a car fax on it and its all true and clean.
Old Oct 27, 2013 | 12:54 PM
maxwelltarpeh's Avatar
hello I got a 2001 a6 and my battery went dead now the radio went into the SAFE mood and I cant retrieve the code because the radio card wasn't in the car when I purchase it .. how can I retrieve that radio code
Old Oct 27, 2013 | 09:13 PM
Not sure, there might be a better section to ask that question here on AF, good luck!!
morpheous
Apr 5, 2011 12:57 PM
B5Bobby
Aug 30, 2009 06:14 PM
DEDMN_TT
Nov 18, 2007 04:31 PM
outasflyguy
Jul 9, 2007 12:36 AM
