VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Pin Code help for a BEER
Old Jul 21, 2015 | 11:22 AM
californiadaddy's Avatar
Default Pin Code help for $50.00 PayPal Gift
Can someone remind me how to pull the PIN code on a 2004 audi a4. I have been out of the game for a while. I have the Ross Tech Vag-com. I just forgot how to do it. I have a buddy that needs me to reprogram his new keys.
I buy someone a beer and paypal you $50.00 if you can help.
Thanks
Old Jul 21, 2015 | 04:15 PM
Here is his current scan.
Tuesday,21,July,2015,12:06:45:22822
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
Ross-Tech: Home
VIN: WAUJC68E33A258071 License Plate: STEVE AUDI
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUJC68E33A258071 Mileage: -10127miles
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 FF
Component: V30 01J 1.8l5VT USA 3011
Coding: 00001
Shop #: WSC 04940
VCID: 75E1119A4F9810894D9-5140
3 Faults Found:
18165 - Supply Voltage
P1757 - 35-00 - Open Circuit
18270 - Powertrain Data Bus
P1862 - 35-10 - Missing Message from Instrument Cluster - Intermittent
17111 - RPM Signal from ECU
P0727 - 35-10 - No Signal - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 G
Component: ABS/ESP front 2328
Coding: 04279
Shop #: WSC 02610
VCID: 2C57F4FEDC521141E27-5122
4 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
18258 - Powertrain Data Bus
P1850 - 35-00 - Missing Message from ECU
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 29590DEAD3A00469191-515E
5 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
00474 - Control Module for Immobilizer
49-00 - No Communications
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
VCID: 3467EC9E04624981BA7-4B00
5 Faults Found:
00985 - Right Tail Light (M2)
57-00 - Electric Circuit Failure
79-10 - Please Check Fault Codes - Intermittent
01312 - Powertrain Data Bus
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
Shop #: WSC 63351 000 00000
VCID: 377DDB924514A2999F5-515E
11 Faults Found:
00003 - Control Module
014 - Defective - MIL ON
00588 - Airbag Igniter; Driver Side (N95)
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
011 - Open Circuit - Intermittent
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
VCID: 3E73CEB63A2E93D15C3-4B1A
2 Faults Found:
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 02200
Shop #: WSC 19411
VCID: 326BEA86FE7647B1A8B-5140
WAUJC68E33A258071 AUZ6Z0B0383674
4 Faults Found:
01176 - Key
65-10 - Unauthorized - Intermittent
01314 - Engine Control Module
01304 - Radio
65535 - Internal Control Module Memory Error
00-00 - -
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
VCID: 72EB2A863EF607B168B-4B1A
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0002
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
80-00 - Single-Wire Operation
End-------------------------(Elapsed Time: 05:59)--------------------------
