VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
throttle body/VAGCOM gurus
Old Jul 4, 2007 | 02:23 PM
pilot5.0's Avatar
Default throttle body/VAGCOM gurus
Still have having throttle body issues. '99 1.8T.VAG - 17973throttle control(j338) Fault in basic setting p1559-35-00, 17973 throttle actuator(j388) Lower stop not reached p1565-35-00.
Getting error with electronic TBA. ERROR for Throttle valve pot voltage, NOT for Operational status.
Vehicle runs fine(minus CEL), idles fine, seams a little different with compression braking of engine while applying brakes.
Any advice thanks in advance. Throttle body or vacuum pot system?
Old Jul 4, 2007 | 02:40 PM
mickyboy10001's Avatar
Default RE: throttle body/VAGCOM gurus
Hi mate just got same type of code come up on my Audi a4, see post above no idea what to do, i have replaced throttle bodys still to no joy, just be careful as mine has completely gone, if you find out anymore than me please let me know.
kind regards mick
Old Jul 4, 2007 | 03:48 PM
2k S4's Avatar
Sounds like the pedal sensor, if you clear the code, & it pops right back up, chances are the part needs to be replaced.
Old Jul 4, 2007 | 04:49 PM
auditech79's Avatar
^^^ Yeah, looking it up in the factory repair manual for that fault code the only repair is to replace the pedal sensor/actuator.
Corey2222
Feb 25, 2011 07:35 PM
kraylon
Sep 2, 2009 09:32 PM
TTsteve
Mar 20, 2007 11:02 PM
16w/A4
Feb 4, 2006 06:34 PM
