vag-com report help?
i had this vagcom report need help as im not sure which is issue is causing the others.
Sunday,06,October,2013,16:52:47:06461 VCDS Version: Release 11.11.6 Data version: 20121223 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1K0 Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 56 VIN: WAUZZZ8P14A087245 Mileage: 158720km/98624miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: 022-906-032-BDB.lbl Part No SW: 022 906 032 CB HW: Bas isX 3 Component: MOTRONIC ME7.1.1 5604 Revision: 00000000 Serial number: AUX7Z0C8FNO0AV Coding: 0000178 Shop #: WSC 06435 000 00000 VCID: 4D950487D4C823709BD 9 Faults Found: 18025 - Glow Plug Pre-Heat Indicator (K29) P1617 - 001 - Open or Short to Ground - Intermittent 16395 - Bank 1: Camshaft A (Intake) P0011 - 008 - Retard Setpoint not Reached (Over-Advanced) - MIL ON 16825 - EVAP Emission Control Sys P0441 - 002 - Incorrect Flow - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - MIL ON 16687 - Cylinder 3 P0303 - 002 - Misfire Detected - MIL ON 16690 - Cylinder 6 P0306 - 002 - Misfire Detected - MIL ON 16686 - Cylinder 2 P0302 - 001 - Misfire Detected - MIL ON 16689 - Cylinder 5 P0305 - 001 - Misfire Detected - MIL ON 16688 - Cylinder 4 P0304 - 001 - Misfire Detected - MIL ON Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-300-0xx.lbl Part No SW: 02E 300 046 D HW: 02E 927 770 G Component: GSG DSG 0606 Revision: 02100224 Serial number: 00000000008157 Coding: 0000020 Shop #: WSC 06435 000 00000 VCID: 183BA5D32B8A96D8F8B No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl Part No: 1K0 907 379 E Component: ESP ALLRAD MK60 0103 Coding: 0021128 Shop #: WSC 06435 000 00000 VCID: 34637163572252B8F43 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 C HW: 8P0 820 043 C Component: KlimavollautomatH11 0130 Shop #: WSC 06435 000 00000 VCID: 2C5369038F120A78AC3 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 186 Reset counter: 232 Mileage: 112268 km Time Indication: 0 Date: 2011.03.21 Time: 23:26:48 Freeze Frame: Voltage: 14.20 V Temperature: 13.0°C (no units): 127.0 (no units): 31.0 Temperature: 5.5°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl Part No SW: 8P0 907 279 A HW: 8P0 907 279 A* Component: Bordnetz-SG 1.0 H29 0501 Revision: 00029000 Serial number: 00000000191420 Coding: 018CCF01A0141000000000000000000000 Shop #: WSC 00000 000 00000 VCID: 3B715A5F7A7C9DC0359 Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB Component: Wischer WWS Audi350 0180 Coding: 16711696 Shop #: WSC 00000 1 Fault Found: 02071 - Local Databus 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0411602 Shop #: WSC 06435 000 00000 VCID: 45853CA70CB8DB3053D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8P0-953-549.lbl Part No SW: 8P0 953 549 HW: 8P0 953 549 Component: Lenksäulenmodul H09 0020 Coding: 0011112 Shop #: WSC 06435 000 00000 VCID: FBF11A5FBAFCDDC0F59 Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 980 J HW: 8P0 920 980 J Component: KOMBIINSTR. VDO H25 0110 Revision: D07 Serial number: 2248CD07003612 Coding: 0001403 Shop #: WSC 00370 210 70711 VCID: 3E77534B696E88E8127 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H08 0090 Revision: 08 Serial number: 24001039032C84 Coding: BF0F0340070101 Shop #: WSC 06435 000 00000 VCID: 26479B2B91FE30287A7 2 Faults Found: 01305 - Databus for Infotainment 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 254 Reset counter: 223 Mileage: 93175 km Time Indication: 0 Date: 2010.02.27 Time: 17:04:09 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 223 Mileage: 93175 km Time Indication: 0 Date: 2010.02.27 Time: 17:04:13 ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 Component: HALDEX 4Motion 0101 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: EADF2F1BC56654481EF No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 980 J HW: 8P0 920 980 J Component: KOMBIINSTR. VDO H25 0110 Revision: D07 Serial number: AUX7Z0C8FNO0AV Shop #: WSC 00000 000 00000 VCID: 3E77534B696E88E8127 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl Part No: 8P0 959 801 A Component: Tuersteuerger. H10 0010 Coding: 0000048 Shop #: WSC 06435 000 00000 VCID: 397D40577040AFD0275 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K2 909 144 D Component: EPS_ZFLS Kl.10 1201 Shop #: WSC 00000 000 00000 VCID: 2D556407B4080370BBD No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 Component: KSG H02 0040 Coding: 008800186D288505485AC63000 Shop #: WSC 06435 000 00000 VCID: F9FD0057B0C0EFD0E75 Component: Sounder No Answer Part No: 1K0 907 719 Component: Neigungssensor 002 0002 Part No: 8P0 951 177 Component: Innenraumueberw.H03 0010 3 Faults Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication 01134 - Alarm Horn (H12) 000 - - 01565 - Luggage Compartment Light (W3) 007 - Short to Ground ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl Part No: 8P0 959 802 A Component: Tuersteuerger. H10 0010 Coding: 0000048 Shop #: WSC 06435 000 00000 VCID: 3A7F5F5B7546A4C82EF No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached End --------------------------------------------------------------------- |
