VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
vag-com report help?
Old Oct 6, 2013 | 01:07 PM
Jamie85's Avatar
Default vag-com report help?
i had this vagcom report need help as im not sure which is issue is causing the others.
Sunday,06,October,2013,16:52:47:06461
VCDS Version: Release 11.11.6
Data version: 20121223
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 56
VIN: WAUZZZ8P14A087245 Mileage: 158720km/98624miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CB HW: Bas isX 3
Component: MOTRONIC ME7.1.1 5604
Revision: 00000000 Serial number: AUX7Z0C8FNO0AV
Coding: 0000178
Shop #: WSC 06435 000 00000
VCID: 4D950487D4C823709BD
9 Faults Found:
18025 - Glow Plug Pre-Heat Indicator (K29)
P1617 - 001 - Open or Short to Ground - Intermittent
16395 - Bank 1: Camshaft A (Intake)
P0011 - 008 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
16825 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
16687 - Cylinder 3
P0303 - 002 - Misfire Detected - MIL ON
16690 - Cylinder 6
P0306 - 002 - Misfire Detected - MIL ON
16686 - Cylinder 2
P0302 - 001 - Misfire Detected - MIL ON
16689 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
16688 - Cylinder 4
P0304 - 001 - Misfire Detected - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 046 D HW: 02E 927 770 G
Component: GSG DSG 0606
Revision: 02100224 Serial number: 00000000008157
Coding: 0000020
VCID: 183BA5D32B8A96D8F8B
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No: 1K0 907 379 E
Component: ESP ALLRAD MK60 0103
Coding: 0021128
VCID: 34637163572252B8F43
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 C HW: 8P0 820 043 C
Component: KlimavollautomatH11 0130
VCID: 2C5369038F120A78AC3
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 186
Reset counter: 232
Mileage: 112268 km
Time Indication: 0
Date: 2011.03.21
Time: 23:26:48
Freeze Frame:
Voltage: 14.20 V
Temperature: 13.0°C
(no units): 127.0
(no units): 31.0
Temperature: 5.5°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000191420
Coding: 018CCF01A0141000000000000000000000
Shop #: WSC 00000 000 00000
VCID: 3B715A5F7A7C9DC0359
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0411602
VCID: 45853CA70CB8DB3053D
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H09 0020
Coding: 0011112
VCID: FBF11A5FBAFCDDC0F59
Part No: XXXXXXXXXXX
Component: Lenkradmodul H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 J HW: 8P0 920 980 J
Component: KOMBIINSTR. VDO H25 0110
Revision: D07 Serial number: 2248CD07003612
Coding: 0001403
Shop #: WSC 00370 210 70711
VCID: 3E77534B696E88E8127
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 24001039032C84
Coding: BF0F0340070101
VCID: 26479B2B91FE30287A7
2 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 223
Mileage: 93175 km
Time Indication: 0
Date: 2010.02.27
Time: 17:04:09
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 223
Mileage: 93175 km
Time Indication: 0
Date: 2010.02.27
Time: 17:04:13
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554
Component: HALDEX 4Motion 0101
Coding: 0000001
VCID: EADF2F1BC56654481EF
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D07 Serial number: AUX7Z0C8FNO0AV
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 397D40577040AFD0275
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 D
Component: EPS_ZFLS Kl.10 1201
VCID: 2D556407B4080370BBD
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
VCID: F9FD0057B0C0EFD0E75
Component: Sounder No Answer
Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
3 Faults Found:
01134 - Alarm Horn (H12)
000 - -
01565 - Luggage Compartment Light (W3)
007 - Short to Ground
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A7F5F5B7546A4C82EF
Address 56: Radio
Cannot be reached
End ---------------------------------------------------------------------
cgmiller63
B7 Models
Jan 16, 2009 11:10 AM
rbrewer
Aug 14, 2007 12:57 PM
Seagrave
May 30, 2007 02:33 PM
