VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Vagcom code - 17608 - N249?
Old Aug 2, 2010 | 11:25 AM
Viciousandy's Avatar
Default Vagcom code - 17608 - N249?
Afternoon, all
First and foremost, hello to all - this is my first post. Secondly, and this is quite important, I am pretty clueless about cars. I've had a Mk1 TT (2000, 66k) for about a month and a half now and have been having fun finding out about ignotion coils poking up and having to replace them!
I have a friend with vagcom and have a fault code that keeps coming up - 17608 (Boost Pressure Control Valve) N249. From spending quite a bit of time on the web, I *believe* that replacing the N249 DV should resolve the problem, correct? Or could something else be causing the problem?
Finally, has anyone had any dealings with Mark of MDM Technik, based in the Berkshire area? I've been using an independant garage until now, but they used a non-Audi-original ignition coil last time (cheeky bastard!) so I'm keen to ue an Audi specialist from now on but not sure who to use.
Thanks in advance
Andrew
Old Aug 2, 2010 | 02:50 PM
cincyTT's Avatar
I'm make believe
The n249 is under the intake manifold. Most likely has a broken vac line from it to the diverter valve. Coilpacks go bad and if you pay someone to replace them, you are a sucker. www.mjmautohaus.com and www.ecstuning.com are the places to buy most of your replacement parts from and then diy.
Old Aug 3, 2010 | 08:43 AM
Ok, thanks mate. I appreciate your comment about the ignition coils. I know where they're located now so will not be using a garage for those in future!
My friend did the vagcom thing again and the 17608 - N249 fault had disappeared, only to be replaced by a fault to do with the immobiliser (I didn't write down the fault code). He said it's because the ignition coils are sorted now so the boost pressure issue is no more.
So, were the faulty ignition coils linked to the boost pressure fault at all? Apologies in advance for my ignorance.
Old Aug 4, 2010 | 12:01 AM
cincyTT's Avatar
I'm make believe
If the car was misfiring, it would cause issues that would cause the ecu to protect the motor.
Old Aug 4, 2010 | 09:43 AM
coachvtt's Avatar
Hey! Cincy, thnks for the sceematic! Now I will install the MBC and adjust the actuator!
Woop!..Knowin me I blow the bitch the eve at the track....
Old Jul 26, 2013 | 11:28 PM
alex_19preu's Avatar
Default 06 audi a4 2.0t p2293 p2261
I CANT DRIVE MY CAR OVER 100MPH, THE ENGINE WONT RESPONSE , IT LOOSE A LOT OF POWER , I DONT HAVE THE CHECK ENGINE ON BUT I SCANNED MY ECU WITH A SNAP ON SCANNER AND THE SCANNER GAVE ME THOSES CODES? . IM NOT SURE IF THOSES CODES ARE RELATED OR ARE DIFERENTES TYPES OF PROBLEMS KNOWING THAT
P2293 Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
P2261 Boost Pressure Control Valve (N249): Mechanical Malfunction
I WONDER IF ANYONE OF U HAD THE SAME PROBLEM ?
steve-sline-exec
B8 Models
Aug 2, 2015 09:43 PM
whitejeepXJ
Oct 29, 2009 12:21 AM
pimphell
Mar 26, 2008 12:09 AM
Billiam
Jan 15, 2008 08:51 PM
