VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VAGCOM Question??
Old 11-11-2008, 08:09 AM
kev659's Avatar
Default VAGCOM Question??
I just did an HID conversion and have been having problems with my break, abs, and ESP lights coming on when i turn on the hid lamps. Also it will knock out my speedomitor. After i turn the electrical system off and on twice the codes clear out and everything goes to normal. I was reading that with the vagcom tool you can choose what type of light you have in the car. Do you guys think that this will solve the problem? Also does vagcom log the errors?
Old 11-11-2008, 11:19 AM
auditech79's Avatar
No, you must have wired something incorrectly, take it back to stock and see if it still does it. If it works fine stock, what kind of HID kit are you using? Ebay perhaps?
Old 11-11-2008, 12:06 PM
kev659's Avatar
I have gone back to stock and the error does not come up. I got the units from vvme. It is a plug and play system. My interpertation of this problem is that the inrush current to turn on the ballast is pulling power from the system and causing the error to come up. Once the ballast is charged then the error will not come up. That is why i think that changeing the option in the ECU will let the car see that the current on the line will be greater because of the bulb being used.
starving030
02-23-2014 04:14 PM
bobrug30
08-05-2013 02:17 PM
brimhall99
10-28-2008 05:27 PM
falcompsx
04-27-2008 03:37 AM
hxgaser
04-25-2008 06:54 PM
Quick Reply: VAGCOM Question??
