VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Vagcom tweak -- emergency flashing brake lights
Old Dec 25, 2010 | 11:52 AM
dbonyad's Avatar
Default Vagcom tweak -- emergency flashing brake lights
Hi,
I have a 2009 Audi A4. I have performed many of the Vagcom tweaks available (I have my own kit). Every single one of them works absolutely great, and every change I make is instantly effective.
The only problem I'm having is with the emergency braking tweak. I think this is an important feature for safety reasons but I can't get it to work. In Vagcom I have enabled BOTH the flashing brake light and hazard light activation on heavy braking.
Over the past months there have been a few situations where I've had to perform very heavy (emergency) brakes -- that is as much force to the pedal that I can physically apply. These have been at a variety of speeds.
In none of these situations have the hazard lamps activated (you can see on the mirrors whether they are on). Obviously I can't see the brake lamps but I assume these are constant and not flashing if the hazard lamps aren't activated.
Does anybody know:
  • Why these are not working? Is there something extra I need to do decide tick the two boxes in the Vagcom software?
  • Is there a certain speed range where this feature becomes active?
  • Have any of you managed to get this feature to activate?
Thanks a lot for any advice,
Davood
SILVERSVS
Apr 30, 2011 06:31 PM
sushidub
Oct 6, 2010 12:38 AM
fidelite
Feb 3, 2009 11:04 PM
sergey_f13
Aug 26, 2008 06:32 PM
