Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
18 x 8.5" +25 on A6 widebody 4.2 ?
Old Feb 18, 2011 | 02:09 PM
CasopoliS's Avatar
Default 18 x 8.5" +25 on A6 widebody 4.2 ?
I want to find aggressive, concave wheels for my 2000 A6 4.2 widebody. I have heard of people using spacers with +35 wheels, so do you guys feel it is possible to run +25 wheels on the widebody?
Any wheel suggestions on the concave look I am going for?
Also, can I run a 255/35/18 tire? It sure seems like there is a lot of room under there.
Thank you in advance for your help.
Old Feb 18, 2011 | 02:22 PM
CasopoliS's Avatar
I found some AMG replica wheels that might not look bad:
http://www.tulipcitywheels.com/merce...cedes-18.shtml
Part #:
MB16-18-GM-L
Old Feb 18, 2011 | 03:02 PM
CasopoliS's Avatar
I guess I am spamming my own thread, but would 18 x 9.5" be an option. If so, what offset should I go with? There might be more options for me with a wider rim, I just don't know if it will fit.
Old Feb 21, 2011 | 07:04 PM
AWDaholic's Avatar
Senior Administrator
Not a lot of A6ers, in here, huh? Try posting the same question in the A6 section of the forums, too, if you haven't already done so. You may find better help. The A6 crowd tends to be more insular, in their nature. Seldom venturing out beyond the A6 section, I've noticed.
Good luck!
Old Feb 22, 2011 | 05:44 PM
Miles@TireRack.com's Avatar
Hey CasopoliS, I think I can help with a few of your concerns.
First, the 255/35-18 would be a great fit so no worries about that! It's harder to fit this size on some of the other Audis of this year but the flared fenders give you extra room the other models don't have.
As for the wheel, I see an 18x8.5 should clear well and the 18x9 should be close. So close, that it makes me think the 18x9.5 might start to rub the suspension parts. The 8.5'' width can be used with an offset anywhere from 30-40mm with no problem.
I don't really like to work with spacers because of the increased stress they can put on the ball joints. Already had problems with that and the repair cost was something worth avoiding.
Old Feb 23, 2011 | 04:42 PM
CasopoliS's Avatar
Thank you very much for the helpful information. I will stick with 18 x 8.5
Now I have to decide what the benefit of that size tire is over a more "standard" tire size... there is a big price difference.
Old Mar 7, 2011 | 08:47 AM
As a general guideline, wider width means more rubber touching the road so you get more responsiveness and handling. The only detriment would be snow/ice traction where you need a slimmer width to slice that tire through it instead of roll over it.
