Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Fix-A-Flat & TPMS
Old Mar 11, 2011 | 11:44 AM
idgara73612's Avatar
Default Fix-A-Flat & TPMS
Anyone ever had problems using fix-a-flat in a tire with TPMS? I've heard that it can cause problems, and to "please consult the manufacturer before you add a can to your roadside emergency kit."
Just wondering if anyone has any input or advice on this, as i'm getting my new A4 w/ TPMS in about a week. Thanks!
Old Mar 11, 2011 | 04:46 PM
Miles@TireRack.com's Avatar
The problem with Fix-a-Flat is that the goop you spray into the puncture to seal it up can gum up the sensor and render it ineffective. If your vehicle has a metal valve stem/direct TPMS then it would be susceptible to this.
If you're not sure if you have a sensor in your wheel, let me know the full YMM and I would be happy to find out for you.
Old Mar 13, 2011 | 06:44 PM
I'm getting an '11 A4 Quattro Premium Plus. I know it has TPMS, but I don't know enough about it to know what kind, if there are different kinds (?).
I have a can of fix a flat for a truck I have, which I just noticed says right on the can "tire sensor safe", which sounds good. But I'd still like to have someone tell me not to worry about using it on my A4
Old Mar 14, 2011 | 09:57 AM
No worries! The '11 A4 Quattro TPMS sensor is not inside the wheel. Instead, it's a part of the ABS system so you can use fix-a-flat without a sensor complication.
Old Mar 14, 2011 | 12:36 PM
Hey that's great to hear! Thanks Miles!
Makes me feel good to have a can with me. And makes me feel even better that i can actually use it!
mmerrick
Nov 25, 2012 09:33 PM
abacabdan
Oct 13, 2010 10:25 PM
Terry621
Sep 1, 2010 09:50 PM
austindgarner
Apr 30, 2008 12:44 AM
Ports6689
Feb 21, 2007 09:57 PM
