Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Help! Strange Noise from front right wheel!
Old Aug 6, 2012 | 06:00 PM
Dinesh Dave's Avatar
Default Help! Strange Noise from front right wheel!
So I purchased a used Audi A3 2010, a few weeks ago... and I took it to a shop to get it checked out, everything came back good apart from the tires which there were 4 different tires on the car which the guy at the shop said was a problem.
I was just wondering if anyone has come across the same issue here?
Also im a first Audi owner! Love it!
Cheers!
Old Aug 7, 2012 | 08:16 AM
lance@tirerack.com's Avatar
Former Sponsor
Hi Dave,
The gentleman at the shop is correct. When you have mismatched tires they can create an imbalance in the car. In additional to strange road noise you may experience strange handling and response as the tires do not match. The best way to think of it is like this, you wear the same shoes on both feet for the most comfort. If you wore 2 different shoes you would feel off balance or not as comfortable. It's the same with tires on your car. Let me know if you have additional questions or would like to get your tires replaced, I can certainly make some suggestions.
Old Aug 10, 2012 | 09:52 PM
Docnar's Avatar
I had a similar problem with road noise. Take the following steps:
1. 4 wheel alignment
2. Balance tires.
3. Use all the same type of tires.
4. rotate tires until noise gets less.
5. replace tires
Old Sep 6, 2012 | 07:22 PM
Docnar's Avatar
check inflation pressure. for extra load tires, use 38 psi 18 inch rims. Add 1 psi for each increase in rim diameter. Over inflated tires make more noise
Paul h
Feb 18, 2014 01:28 PM
hhbayer
B7 Models
Mar 17, 2013 07:49 PM
SuperSage
Jul 19, 2011 04:28 PM
AudiA606
Jan 28, 2008 01:08 PM
antoncole
Nov 9, 2006 12:31 AM
