Need help with offset!!!
I wanna buy some new wheels. I have stock 18x8 mercadies 5bar wheels right now. Offset??? Idk
I wanna buy some ESM 002r wheels. I was thinking 17x10 but I need help finding out what kind of offset I would need??? |
Hard to respond considering you didn't list your model/year (and thereby stock configuration), whether you have any suspension mod's, etc. Also what your expectations may be - show or go?
Sorry new to this. I have a 2005 A6 AWD lowered on H&R springs. And I'm just going for show.
It appears (Tirerack.com) that your stock are:
17x7.5 Offset: 40mm Backspacing: 5.82" Bolt Pattern: 5-112 Rec. Tire Size:245/45-17 -or- 18x8 Offset: 40mm Backspacing: 5.82" Bolt Pattern: 5-112 Rec. Tire Size:245/40-18 As you're lowered (how much?) you'll have to consider lower [sidewall] profile tires the larger the wheel you select, to prevent rubbing. You'll also have to consider offset and/or "roll" your wheel well lips depending how aggressive you go. The higher the positive offset number the more "tucked in" the wheel is, but for 'show' you want a lower number so the rims are more flush with the outside of the fender. btw: another option is to go with [less expensive] standard wheels and use spacers. http://www.ecstuning.com/Audi-C6_A6-...heels/Spacers/ |
Thank you
It was only a 1.5 drop |
