Need help with offset!!!
I wanna buy some new wheels. I have stock 18x8 mercadies 5bar wheels right now. Offset??? Idk
I wanna buy some ESM 002r wheels. I was thinking 17x10 but I need help finding out what kind of offset I would need???
It appears (Tirerack.com) that your stock are:
17x7.5
Offset: 40mm
Backspacing: 5.82"
Bolt Pattern: 5-112
Rec. Tire Size:245/45-17
-or- 18x8
Offset: 40mm
Backspacing: 5.82" Bolt Pattern: 5-112
Rec. Tire Size:245/40-18
As you're lowered (how much?) you'll have to consider lower [sidewall] profile tires the larger the wheel you select, to prevent rubbing. You'll also have to consider offset and/or "roll" your wheel well lips depending how aggressive you go. The higher the positive offset number the more "tucked in" the wheel is, but for 'show' you want a lower number so the rims are more flush with the outside of the fender.
btw: another option is to go with [less expensive] standard wheels and use spacers. http://www.ecstuning.com/Audi-C6_A6-...heels/Spacers/
17x7.5
Offset: 40mm
Backspacing: 5.82"
Bolt Pattern: 5-112
-or- 18x8
Offset: 40mm
capn
Nov 14, 2012 05:34 PM
Mr. Merk
Mar 4, 2008 08:43 PM
