Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
need to replace 19" with 17" - advice needed!
Old Feb 27, 2012 | 05:29 AM
jraward's Avatar
Default need to replace 19" with 17" - advice needed!
I have an A4 Black ed with 19" rims on it.
I want to store the 19"s and buy some sensible 17"/18" but I don't know what to look for.
the stock ones take 255/35R19
What else can I use?
I've found some 235/45R17 which would do the job - would the size difference (I've calculated a ride change of -8.9mm with the new wheels) be ok?
I've never changed wheels before so this is all new to me!!
Old Feb 27, 2012 | 05:49 AM
shipo's Avatar
I ran your 255/35 R19s through my handy-dandy tire size calculator and came up with a circumference of 81.77"; the closest I could get to that in a tire with a 235 section width mounted on either a 17" or 18" wheel was a 235/50 R17 which has a circumference of 82.47". Here in the States there are plenty of tires in that size available, and at prices which range from a relatively modest $115 per tire to a rather painful $298 per tire.
Let us know how you make out.
Old Feb 27, 2012 | 07:44 AM
jraward's Avatar
255 tyres are a painful £230 / corner hence the change!!!!
Old Feb 27, 2012 | 08:05 AM
shipo's Avatar
Ouch! Sounds like you can buy a complete set of 235/50 R17 tires and 17x7.5 or 17x8.0 wheels for less than a single set of 255/35 R19 tires.
Old Feb 27, 2012 | 09:27 AM
jraward's Avatar
What does 18x8J mean? 18 diameter, 8 width, what's the J?
They're the stock s-line wheels that I would want to get, the 17s seem tricky to match to the car.
Old Feb 27, 2012 | 10:32 AM
shipo's Avatar
To be quite honest, I don't know what the "J" stands for, however, most if not all wheels I've looked at, regardless of size, has a "J" imprinted in the wheel size. Said another way, the 18x8J S-Line wheels will fit your car perfectly.
Old Feb 28, 2012 | 08:05 AM
lance@tirerack.com's Avatar
Former Sponsor
What year is the A4? Which trim level do you have? I can take a look for you and see what we would suggest.
Old Mar 1, 2012 | 09:26 PM
susyhun's Avatar
Hi All, not sure if still looking for tyres I just found your tyre size for £126/tyre fully fitted and delivered to your choice of place on Blackcircles.com.
Good luck
