Tire Pressure?
I was noticing a slight vibrating in my ride, so I stopped and checked the air pressure in the tires. I found that the recommended tire pressure for the car is 42 psi??? Does this sound right to everyone? I thought it was a little high. I was about 15psi low in three of the tires. I filled them up and now the car is back to it's smooth ride.
I have a 2001 A6 4.2L Quattro. It has all available options and packages which includes the lower profile tires. Any assistance would be great.
Thanks!
Thanks!
I put almost 25 PSI in one of the rear tires, so that was pretty close to flat. The car is running awesome now but not sure about putting over 42psi in them? I'm kind of scared to over inflate. Thanks for the reply!
That's where I was a little confused because there is a 42 psi and then there is a very large print 46psi? I've never seen it like that, so I just stuck with the 42psi.
ok ok ok... 42 is too high by about 6. where did you see 42psi recommended? if you read it on the tire sidewall, that's a max pressure for max load, not the recommended pressure for comfort, performance, safety and treadwear.
