Intermittent Limp Mode (PRNDS flashing/disappearing) and CAN-Bus communication collap
Old Feb 27, 2026 | 03:38 AM
kuchari's Avatar
Default Intermittent Limp Mode (PRNDS flashing/disappearing) and CAN-Bus communication collap
Hi, I have a problem with my a4. its happening after few minutes of drive (20minutes)
Symptoms:
  • PRNDS Display: Randomly starts flashing or disappears entirely from the instrument cluster.
  • Instrument Cluster: Gauge needles (RPM, Speedo) bounce or drop, and "Oil Pressure" warning pops up despite sufficient oil levels.
  • Trigger: Usually occurs under load (acceleration) or during gear shifts
  • Recent Repair: Replacing the Power Supply Relay (Relay 614/J271) stabilized the car for 1.5 days, but the issue returned.
Diagnostic Codes (VAG-COM/KDiag):
  • P1881 – Acceleration Signal missing message.
  • 01312, 01314, 01315 – Data Bus drivetrain communication failure (ECM/TCM/ABS).
  • P1626, P1648, P1682 – Missing messages from Transmission and ABS modules.
  • P1852, P1854 – Implausible messages on the drivetrain bus.
can you help me please?
thank you
File Type: pdf
a4audikid
Jul 27, 2012 10:56 PM
Torchwork
Jul 14, 2012 09:03 AM
DH4Z3
Mar 21, 2012 08:10 PM
TurboPoster
Oct 20, 2009 09:46 PM
yhashish
Feb 12, 2006 03:16 PM
