Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
2012 Audi A5 need turbo - P0299
Old 12-27-2020, 11:13 AM
jpjmustang's Avatar
Default 2012 Audi A5 need turbo - P0299
Have the P0299 underboost on a 2.0T Audi A5 (2012) replaced with used turbo 94 K used - still threw the same codes
94K was from a 2009 Audi A4 - was told it was good - so replaced blow off and control valve
Still throwing codes - Is it worth rebuilding? - I just want to sell this A5
Any help would be useful......
JPJM
Old 07-19-2023, 08:21 PM
GreenEdge's Avatar
Arrow www.turbobend.com
Your turbo maybe done, The good news is that you no longer need to put a new turbo. You can fix it in a minutes by using the turbo bend tool
www.turbobend.com
Good luck
Old 01-15-2024, 01:36 AM
davideidson's Avatar
Repeated P0299 codes on your 2012 Audi A5, even after replacing the turbo, blow off, and control valve, may indicate persistent underboost issues. Before considering a rebuild, check intercooler connections, vacuum lines, and the wastegate for leaks. Ensure proper installation and functionality of the used components. If problems persist, a professional diagnostic might reveal other issues affecting performance. Evaluate repair costs against the A5's market value to determine if a rebuild is financially justified. Transparency about the issue when selling is advisable. Seek expert advice to make an informed decision on whether to continue troubleshooting or sell as-is.
Jerrycutshaw
12-08-2018 01:43 PM
hamodi123
09-07-2016 01:41 AM
jthorese
06-08-2012 05:25 AM
ShootMike
03-05-2012 03:50 PM
Andrew Nelson
03-05-2012 03:48 PM
Quick Reply: 2012 Audi A5 need turbo - P0299
