Audi A2 This compact Audi A2 offers a lightweight aluminum structure which allows the small yet efficient engine to offer performance comparable to others in its class.
A2 Rear Bulb?
Old 08-29-2011, 11:06 AM
L4AH4N's Avatar
Lightbulb A2 Rear Bulb?
Hi Guys,
Would anyone be so kind as to tell me how to change the rear light bulb on an Audi A2.
Many thanks.
Old 08-30-2011, 08:31 AM
Sarge786's Avatar
If you look from the inside, at the back of the light area, you will plastic covers, these will have a place to put your finger into and pull the plastic cover out, after this you will see the rear of the bulb holder, there are 4 clips you need to slightly squeeze together while pulling out, this panel will come out holding the bulbs, refitting is the reverse
Cheers
Sarge
Old 10-09-2012, 08:01 AM
Sarge786's Avatar
Originally Posted by carol123
How do you change headlight bulbs on a audi a2
It is easier to remove the complete headlamp assembly, remove bonnet, and there are two bolts to remove it, one on top of the headlamp and other one next to the inner side level along the bottom of the headlight where the front flap would be if the bonnet was on, if you see what I mean. You will need a star key to remove the bolts and it all takes about a minute to remove
Cheers
Sarge
krishcanag
03-29-2011 04:59 PM
mikekey
02-04-2010 05:28 PM
gillfish
02-26-2007 04:27 PM
Ifty
01-10-2006 08:18 PM
ttjenny
09-03-2005 07:28 PM
Quick Reply: A2 Rear Bulb?
