A2 Rear Bulb?
If you look from the inside, at the back of the light area, you will plastic covers, these will have a place to put your finger into and pull the plastic cover out, after this you will see the rear of the bulb holder, there are 4 clips you need to slightly squeeze together while pulling out, this panel will come out holding the bulbs, refitting is the reverse
Cheers
Sarge
Cheers
Sarge
It is easier to remove the complete headlamp assembly, remove bonnet, and there are two bolts to remove it, one on top of the headlamp and other one next to the inner side level along the bottom of the headlight where the front flap would be if the bonnet was on, if you see what I mean. You will need a star key to remove the bolts and it all takes about a minute to remove
Cheers
Sarge
