A3 1.9tdi tempreture gauge not working?
Old 10-25-2014, 09:12 AM
Pullafacial's Avatar
Default A3 1.9tdi tempreture gauge not working?
Hi. I've just picked up a 2002 a3 1.9tdi and have noticed the tempreture gauge is not moving. After reading lots of info I convinced myself it was the tempreture sensor but changing it has hit fixed the problem. It does blow hot air so I guess it is actually getting warm and I also notice that the pipe going into the top of the rad is hot but the pipe coming out the bottom is cold? Can anybody advise as I can't afford to keep guessing and changing parts that don't need replacing. Thanks in advance.
Old 10-29-2014, 04:20 PM
gsjohal's Avatar
As you know, diesels take a lot longer to get to normal operating temp. However if you are running it long enough and the bottom hose is still cold, then there is a problem. The coolant isn't circulating around the engine and the most common cause is the thermostat not opening.
Old 11-10-2014, 08:21 AM
littleA3's Avatar
Old 11-11-2014, 08:44 AM
Thanks for your help.
I've now changed the temp sensor and thermostat and although it will now get to tempreture, it takes about 15-20 miles!
Jet Force
10-06-2014 07:35 PM
Jet Force
10-06-2014 07:10 PM
gedas429
05-26-2009 04:07 PM
obsolete
05-07-2007 12:29 AM
rual
02-28-2006 05:56 PM
Quick Reply: A3 1.9tdi tempreture gauge not working?
