:: ECS Tuning :: NEW!! ECS Luft-Technik Intake System | Audi 8V A3
ECS is proud to announce the all new Luft-Technik Induction System for the Audi 8V A3/S3!
Engineered for exact fitment, install is a breeze; only requiring simple hand tools. Featuring a dual air inlet scoop, airflow is channeled from both sides of the engine bay for maximum available airflow. The main heat shield assembly is perfectly designed to seal against the hood to further stave off engine bay heat to maintain repeatable power delivery.
With reduced turbo lag, stunning aesthetics and maximum power gains, this is THE BEST intake system on the market today.
Proven Performance
- Maximum Gains: +6.0 Wheel Horsepower @ 5,300 RPM and +6.0 Ft/lbs of Torque @ 5,200 RPM
- Peak Gains: +5.0 Wheel Horsepower @ 5,300 RPM and +1.0 Ft/lbs Wheel Torque @ 2,700 RPM
- Largest peak HP and Torque gains are between 4,500 and 6,800 RPM for consistent mid to top-range boost in power!
- Turbocharger efficiency is also improved by reducing restriction ahead of the compressor, resulting in less boost pressure needed to produce more power. At 6,000 RPM the ECS Luft-Technik Intake made +6.0 WHP over the stock intake system with 1.8psi lower boost pressure.
Click HERE to order or for more information
Fits:
Audi 8V A3 1.8T 2014+
Audi 8V A3 2.0T 2014+
Audi 8V S3 2014+
Let me know if you have any questions.
Jason
ECS Tuning
B7 Models
07-19-2016 01:24 PM
ECS Tuning
01-04-2016 01:02 PM
ECS Tuning
B8 Models
01-04-2016 12:46 PM
ECS Tuning
S4
11-19-2015 10:37 AM
ECS Tuning
S5
11-19-2015 10:36 AM
