suspension shield removal
Old 06-17-2008, 11:49 PM
chusaiyan's Avatar
Member
Default suspension shield removal
for those of you who have the same problem with the loose rear suspension shields that make a real annoying rattle when going over uneven roads, those shields are strongly recommended not to be removed by the dealer i spoke to. they said it protects the brake lines from debri and provides better airflow to the brakes. Im taking it in tmr to see what else they can do to it to stop it from losening up and rattling. for those of you who are experiencing or have experienced the same problem did ur dealer tell you the same thing?
Old 06-18-2008, 01:10 AM
4RINGSROD's Avatar
Default RE: suspension shield removal
I would pull the bolt out and add locktight to them and then just crank really hard on them upwards to about 90-100lb torque
Old 06-26-2008, 08:54 AM
dzasta's Avatar
I just had my stealership check my stone shield/guard for a rattleand they said a piece of it was broken off and was the source of my rattling. The bad news is that its NOT covered under warranty and I have to pay $50 bucks or so for the part. I remember in some prior threads where someone had it replaced under warranty...
At this point, id rather pay $50 and have the rattle fixed...
Old 06-26-2008, 07:26 PM
canuckA3's Avatar
Not having received my car yet.....can I ask what this piece is shielding on the suspension? Is it required?
99a4wagon
12-10-2010 07:03 PM
photojojo
10-29-2010 10:29 PM
chusaiyan
04-10-2010 10:57 PM
QuattroChucko
04-13-2007 09:18 PM
Quick Reply: suspension shield removal
