water pump impeller shear?
Old 08-31-2014, 09:55 PM
jjwade's Avatar
Default water pump impeller shear?
I have a 2006 Audi A3 and had a timing belt water pump changed out about 5,000 miles ago with the water pump as the dealer was in there changing the intake camshaft under an extended warranty. Turns out the OEM water pump had a failure, it looks like woodruff key on the impeller ( there is one) sheared as you can rotate the impeller freely with respect to the gear.
Has anyone heard of this or seen it? I cannot find anything in the forums.
When you rotate the gear the impeller will rotate too, but if you put any resistance on the impeller it will stop. Unit is 2 years old max.
Old 09-01-2014, 04:57 PM
jjwade's Avatar
Default pics
pics attached.
Attached Thumbnails water pump impeller shear?-1.jpg   water pump impeller shear?-2.jpg
arnolds64
05-12-2011 05:58 PM
CCA4
01-25-2011 06:38 PM
Quick Reply: water pump impeller shear?
